What are common problems of 02 V6 Accord?
Old Feb 17, 2009 | 04:10 PM
car5car's Avatar
Default del
del
Old Feb 17, 2009 | 04:23 PM
slomofo's Avatar
GDD Member
Default Re: What are common problems of 02 V6 Accord?
P0401 Insufficient EGR flow detected.
Old Feb 17, 2009 | 05:31 PM
Targa250R's Avatar
be professional
LoL, don't we know it.
Common problems include:
- bad transmissions; at 134k it is no longer covered under the extended transmission warranty
- EGR ports clogging
- catalytic converter failure - and these cars don't take too well to aftermarket cats; a non-OE cat usually only lasts about a year, while an OE cat lasts a long time but costs nearly $900
- rotary air control valve causing the idle to surge up and down
Other than that, there isn't much specific to the V6. You'll have your problems that are common to all '98-02 Accords, like fuel vent shut off valve failure, front ball joints, sway bar links & bushings, etc. etc.
Old Feb 17, 2009 | 05:36 PM
YeuEmMaiMai's Avatar
OPDS also has a tendency to mess up on the newer ones.
V6 alt usually don't make it much past 100K...but that is a simple fix, extend the wires and install a CLS alt.....
Old Feb 17, 2009 | 07:44 PM
casper.hughes's Avatar
hell boys give it a chance just bc a few of them have those tsb doesnt mean they all do
Old Feb 18, 2009 | 04:46 PM
slomofo's Avatar
GDD Member
Originally Posted by car5car
What to do about jumping idle?
I hate to be an ***, but seriously dude, it's already been covered in this thread. Look at the third post and he tells you the problem.
Old Feb 18, 2009 | 05:42 PM
sublime423's Avatar
Transmissions
EGR failure and clogged ports
Alternators
Catalytic converters (go OEM)
Engine mounts
Those are the big ones other than that they are really good cars.
Old Feb 19, 2009 | 03:14 AM
Targa250R's Avatar
be professional
Check the coolant level in the radiator first to make sure it is full. Add as necessary.
If the coolant level is okay, then the problem is a bad rotary air control valve on the throttle body (the part that has coolant lines running into it). It will sometimes throw a code P0505.
Chad Mccoy
Feb 25, 2019 04:00 AM
Shamus1
Jul 7, 2005 12:28 PM
rhdcrxturbo
Oct 31, 2004 05:17 PM
