ls crank in gsr block
Old Feb 17, 2009 | 03:23 PM
egboy94's Avatar
Default ls crank in gsr block
i was planning do this a while now but i would like to know what bearings/thrust washer will i have to use gsr or ls?? an would i have to use the gsr or ls main caps??
Old Feb 17, 2009 | 04:12 PM
slomofo's Avatar
GDD Member
Default Re: ls crank in gsr block
Use the GSR bearings and caps, but use LS rod bearings.
Also, just an FYI, but you can't change main caps around, they're machined to fit each individual motor.
Old Feb 17, 2009 | 05:21 PM
egboy94's Avatar
thank u
Old Feb 18, 2009 | 04:42 AM
egboy94's Avatar
one other question... can u use bak the gsr girdle or just buy an after one instead??
Old Feb 18, 2009 | 08:49 PM
EJ8chu's Avatar
IMO this is the best way to run an LS/VTEC setup
Old Feb 18, 2009 | 09:13 PM
Mike@CCT's Avatar
Formerly Mike@TSR
You can use the GSR girdle because you will be using the GSR main caps. The main bearings and thrust washers are the same sizing as the LS.
One other thing to keep in mind is to check clearance on the oil squirters. With the added stroke, some piston skirts will come close or touch. Golden Eagle makes plugs for the squirters also.
Old Feb 20, 2009 | 05:23 PM
KuEy's Avatar
yes, use the gsr main caps and ls rods. and you will have to plug the squirters for sure because the ls crank will be hitting the squirters.
acura_b18c1
May 11, 2011 12:46 PM
dc4teg95
Apr 7, 2008 10:40 AM
ganjasnack
Jan 24, 2007 08:30 PM
b20vtech
Apr 27, 2006 08:30 AM
MTP04
Jan 2, 2003 04:30 PM
