Need Help w/Info on how to do a 5 speed convdersion!
Old Feb 17, 2009 | 02:27 PM
401RIguy's Avatar
Default Need Help w/Info on how to do a 5 speed convdersion!
i was thinking about doing a 5 speed conversion on a beater i just bought! but then i dont know what i need and how much everything will cost me!
THIS IS FOR A 93 ACURA INTEGRA AUTOMATIC!
is it worth it if i bought the car cheap? since i did!LOL
but then please let me know what i need inorder to get this done!
-thnxs
Old Feb 17, 2009 | 02:36 PM
jdmitr4dr's Avatar
Default Re: Need Help w/Info on how to do a 5 speed conversion!
Its pretty straight forward on doing a auto to 5spd swap. I did it to my 4dr and it wasn't that hard but just finding the parts was unless u have hookups wit friends.
list of wat u need:
5spd pedal assembly (off aeg works)
clutch master cylinder/reservoir
5spd starter (wit bolts)
5spd ecu
5spd throttle cable
clutch lines (eg works)
5spd flywheel bots (auto's are short)
clutch
auto to manual trans mount or make one? i did
5spd inspection plate (99-00 si works)
hope dis helps
Old Feb 17, 2009 | 02:42 PM
401RIguy's Avatar
Default Re: Need Help w/Info on how to do a 5 speed convdersion!
what is the inspection plate?
thnxs for the info! is there any other way of telling me how to do this?
Old Feb 17, 2009 | 02:50 PM
jdmitr4dr's Avatar
a insection plate is the plate that goes in between the trans and oil pan just to cover the flywheel.
auto has one too. its different in size a b16 will work off the 99-00 si
Old Feb 17, 2009 | 02:51 PM
401RIguy's Avatar
alright thnxs! so how is there any cutting for the gear box?
so i can get the shift linkage to fit right?
Old Feb 17, 2009 | 02:54 PM
jdmitr4dr's Avatar
yes just cut the tunnel where the auto cable went threw out. and make a templete to cover the whole area and have a cutout for the shifter to come threw. Again i had a friend that did for me that made a cover plate.
Old Feb 17, 2009 | 02:56 PM
401RIguy's Avatar
well, its gonna be a first timer for me and the rest of the fellas so iono if it'll turn out right!
but then hopefully things will work out!
Old Feb 17, 2009 | 02:58 PM
jdmitr4dr's Avatar
take your time and if u have a junkyard aroound your area those are a good help too for parts.
Old Feb 17, 2009 | 03:03 PM
401RIguy's Avatar
ILL TRY IT OUT!lol
Old Feb 17, 2009 | 03:09 PM
jdmitr4dr's Avatar
haha. i like how mine turned out like nuthin was modded.
Old Feb 17, 2009 | 03:31 PM
DA3's Avatar
DA3
list of wat u need:
5spd ecu
5spd throttle cable
clutch
hope dis helps
you also need a halfshaft. 90-93 da's are cable so you dont need hydralic lines or the master cylinder the mount u could get from innovative
Old Feb 17, 2009 | 04:45 PM
Mr. Carbon Fiber's Avatar
Correct me if Im wrong but a 93 integra has cable operated transmission. How does EG hardwares work when it has hydralic operated transmission and clutch?
You need a clutch cable, pedals assembly, transmission mount and rear transmission bracket from a DA. You also have to knock out the mounting area on transmission side and weld in a manual ones. Stock throttle cable will work, you just have to take out the kick down cable along with your automatic transmission. Hope this helps!
BTW auto and manual driveshafts are the same. ABS and non ABS will bolt on just the same.
Old Feb 18, 2009 | 02:49 PM
401RIguy's Avatar
so what would i really need for this?
xduB95preludeSi
Jul 25, 2014 12:32 AM
170whp-B16a
Apr 21, 2010 11:18 AM
BeBe
Oct 7, 2004 07:44 PM
Tadoman23
16
Aug 3, 2004 07:02 AM
