swapped auto to manual, and motor wont start
swapped 91 manual in 92 auto accord and jumped the two black and white wires to fake it into neutral, and the other two to get the key out, and motor still wont start...im missing something here....has fire and fuel is there another connection i have to make...............f22a1 tranny on f22a6
Do you make sure when you start to swap you put shifter on P possition?
If you still use ECU stock and D4 is flashing may be you wrong when you hook up the wiring for netral, double check
If you car has shifter lock,you can't pull out your key if not on P possition, if you can be patient you can figure out to hook up wire to be P possition from factory wiring,
ok i feel stupid now...lol...we fouled out the spark plugs trying to start it, we replaced them and now car runs good we had everything right thanks for the help tho
philosofy1
Jul 18, 2005 08:37 PM
