D16A6 head on D15b2
Ok i have a D16a6head im putting on a d15b2 and i was told i needed a y7/y8 cam gear ...ok but was not told what belt i would use to make this work.does any body know? thx
if there is nothing wrong with the b2 head, the cam will fit, put it in and adjust the valves, use the stock belt, I have been running this set up for years, It's the first thing I did to my rex
ok so use the d16a6 camshaft and cam gear in the b2 head with the oe b2 timing belt is what you guys are saying?.....and im doing the mpfi swap at the same time.
yes the pm6 will be lookin for two more injectors and sensors that the a6 dizzy has that the dpfi doesn't and i had a d15b2 with a6 head and single cam zc cam and had to run cam gear and it ran like a champ
You will need an a6 distributor, a resister box, a pm6, the intake mani with everything, the timing belts are exactly the same, and so are the cam gears, the heads are exwactly the same except for the camshaft, it will not lower your compression, you will need to repin the dizzy plug to the old one so you don't have to splice the two plugs, you will also need to run wires for the two new injectors to the ecu, get a chilton and look in the back for schematics
speak a little more clean, but yes but his is also dual point but you can also convert your to multiport and use an a6 camshaft and it will run much better.
Not necessarily....The carbon build up in the old head adds to the compression #. If the new head was clean, the dome space was larger without the carbon build up, thus lowering the compression. Also, the thickness of the (hopefully new or re-useable) head gasket would also effect compression #'s. This could be the scenario. good luck
additional great info:
https://honda-tech.com/forums/showth...6a6+head+d15b2
hopefully it'll save someone some grief
straggs42d15
Dec 13, 2005 10:04 PM
Layziebtnh055
Jun 6, 2004 07:59 AM
JDMs1eeper
Aug 15, 2003 10:52 AM
