Suspension & Brakes Theory, alignment, spring rates....
HELP! Need outer diameter of Integra brake disc top hat
Old Feb 17, 2009 | 07:52 AM
tepid1's Avatar
Default HELP! Need outer diameter of Integra brake disc top hat
As the title states I need the outer diameter of an Integra (GSR if it matters) rear top hat. The year of the car is a 2000. I am trying to make an clamp type adapter for a rear wheel speed sensor for my drag car.
See pic for area in question.
I would appreciate it if someone could check it with a mic for accuracy. I'm going to be drawing this up for a CNC machine.
Thanks in advance
Old Feb 17, 2009 | 12:53 PM
kommon_sense's Avatar
Default Re: HELP! Need outer diameter of Integra brake disc top hat
Not trying to be an @ss, but you could potentially save yourself a lot of headache by just buying a rotor from the local auto parts store to ensure precise measurements.
Also, I would imagine that diameter could vary by rotor manufacturer.
One more thing. brembo has an online pdf with dimensions on all of their rotors. diameter, thickness, hat offset, etc. It may have hat diameter as well. Worth taking a look.
Old Feb 17, 2009 | 08:30 PM
tepid1's Avatar
Well, since I don't have the common liberties that you may have since I'm in Iraq, I can't exactly go out to the auto parts place and pick one up myself.
Thanks for the brembo heads up, but no thanks for the wise *** remark prior to it.
Old Feb 18, 2009 | 12:13 PM
And to think, I was actually going to offer to break out the calipers and measure the rotor sitting in my garage... Good luck with your project...
joshEj1
Aug 26, 2016 02:56 PM
raverx3m
Nov 13, 2010 12:30 AM
donuttes
Jul 5, 2006 02:02 PM
pgpunkguy
Sep 9, 2004 05:07 PM
JediPimpCrx
Sep 5, 2002 01:02 PM
