INTEGRA with a b20b motor??
Old Feb 17, 2009 | 05:16 AM
MadCityVtec's Avatar
Default INTEGRA with a b20b motor??
i found an integra with a b20b motor with type r tranny from japan, and i was wondering if this is a good/reliable motor and trans? its the older motor with about 100k on it, 126hp and 131trqe. so let me know if this is a good motor to by in an integra.
thanks.
Old Feb 17, 2009 | 05:19 AM
Paul-R's Avatar
Default Re: INTEGRA with a b20b motor??
Well the motor isn't really a motor to keep if your not going to convert it to VTEC or turbo, or like in other words not a good motor to keep stock, but a very good building block for future modifications so it's really up to you and your goals you make for it .
Old Feb 17, 2009 | 06:53 AM
hmoobhero's Avatar
shouldnt be too bad. think it like this...its pretty much like a ls motor but more torque but less hp. also, its a plus, you have a itr tranny(lsd). how much they want for it? yea, like paul said, depends what you wanna do with it? just dd or race?
Old Feb 17, 2009 | 01:31 PM
RA429's Avatar
Its actually been proven that with the LS intake manifold, exhaust manifold, and ECU the b20b motor can make just as much hp and more tq than the b18b/a stock. Search it up on here, there is a ton of information on the b20b swap.
Old Feb 17, 2009 | 03:24 PM
b18c1ej8's Avatar
x2, and also you will make those numbers earlier in the powerband.
Old Feb 17, 2009 | 03:27 PM
thanks, ill keep all your suggestions open!
Old Feb 17, 2009 | 09:14 PM
cmoua's Avatar
In CA, the b20 isn't a legal swap in an integra. Thus, check out your local smog laws before you buy the car.
I would say the b20 is an upgrade from the b18a/b. It would out run the b18a/b all day! Additionally, a b20 with I/H/E would be just as fast as a stock gsr if not faster. I say it's faster than a stock GSR because I have one in my integra and I run 15.3 consistently at full weight. I would think that you would need to have a perfect run in order for a stock GSR to hit 15.3 on the 1/4. Just my $0.02!
Old Feb 17, 2009 | 11:08 PM
ALLxMOTOR EG's Avatar
Vietnamese!
The B20 has weaker sleeves,so be careful.
redboost10
Welding / Fabrication
12
Mar 2, 2009 06:19 AM
lsrcrvtec
Apr 8, 2007 07:01 PM
