Alt Belt and Power Steering Belt
Old Feb 17, 2009 | 03:49 AM
218luder's Avatar
Default Alt Belt and Power Steering Belt
Whats the trick for get it tighter. for some reason i cant get it to tighten up. i screwed the tension bolt as much as i can but i still have slack where i can take the belt and push and pull it about half an inch. It squeels like a bat out of hell.
Old Feb 17, 2009 | 04:14 AM
mattsnooz's Avatar
Default Re: Alt Belt and Power Steering Belt
new belts might sqeek a touch.
A half inch play sounds about right.
If you think your doing something wrong take a picture of the tension bolt so we can see what your doing.
SO the other three bolts are loose and you have screwed the tension bolt in soo far that you can't screw it in any furthur but its still not tight enough< Defffinitely take a picture if you feel that is the case because than something is really facked
Old Feb 17, 2009 | 06:41 AM
lude98SH's Avatar
Which belt is squeeling ?
Old Feb 17, 2009 | 06:54 AM
B18_BEN's Avatar
I have the same problem. Bought new belts. Can't get the the powersteering bolt all the way tightened.
Old Feb 17, 2009 | 07:57 AM
mattsnooz's Avatar
You guys have the lock nut backed off and are turning the whole stud right???? You have to back off the "locking" nut than rotate the squared head long nut that goes through the ps mounting bracket "IN' untill the belt has tension
Old Feb 17, 2009 | 07:13 PM
B18_BEN's Avatar
I know that is probably the case, but I cant get my hands back there so I'm stuck with it.
Old Feb 18, 2009 | 04:30 AM
mattsnooz's Avatar
back there???? all the tension bolts for the ps pully are on top.
Unless your issue is only the alternator belt. They are on different pulleys though. One tensioner for PS and one for alternator and AC pump. The alternator and AC pump tensioner bolts is right under the alternator at the front (front of car). You'll see two bolts on one bracket.
Old Feb 21, 2009 | 09:04 PM
218luder's Avatar
i have replaced only the alternator belt at the moment im replacing the p/s tomorrow since i have replace my knock sensor. ill post once everything is finished. Ive checked the tensioner bolt for the alternator and there is no gap between the head of the bolt and the tension bolt bracket, and for the p/s theres about 1/8 of an inch gap. I dont wanna tighten anymore because it feels like im going to break the thing. i just hope its only a bad belt.
Old Feb 22, 2009 | 10:46 AM
nicatlotus's Avatar
Whats up guys.I just bought a 98 lude.My crank shaft pulley was shaking bad so i changed it along with both belts.Everything was working great at first but today my brand new pulley is shaking the same way!(wobbling from left to right)
When i looked at the inside of the old pulley the grooves were pretty much worn all the way down it was nearly smooth to the touch.I was wondering if anyone had any ideas as to whats going on exactly.Any help is appriciated.Thx
Old Feb 22, 2009 | 02:16 PM
TruNinja619's Avatar
do you have the mounting bolts on the powersteering pump or alternator at least slightly loose when you're adjusting the tension on the belt?
Old Feb 22, 2009 | 06:57 PM
218luder's Avatar
yes. i have them slightly loose so i can get it to where i want and then tighten them when i need to.
blackcomet94
Apr 20, 2013 03:04 PM
kelviiv
Sep 18, 2010 07:41 PM
Fo-Do Fanatic
Apr 7, 2010 03:59 AM
jcinwelland
Mar 4, 2009 09:42 PM
Prudz_lude
Jun 17, 2007 03:51 PM
