I have a question about Jun Camshaft kit Stage 1,2,3
Old Aug 9, 2002 | 12:56 PM
AutoXsi2000's Avatar
Default I have a question about Jun Camshaft kit Stage 1,2,3
When someone says they are aggressive, what do they refer that to? Idles rough?
Old Aug 9, 2002 | 01:19 PM
Spade's Avatar
Default Re: I have a question about Jun Camshaft kit Stage 1,2,3 (mano77)
The lobes.....here compare:
Thanx to Katman. Not Jun but you get the idea.
Old Aug 9, 2002 | 07:28 PM
Default Re: I have a question about Jun Camshaft kit Stage 1,2,3 (Spade)
Sorry man, i didn't get the idea. please explain, i'm tryin to buy this. To spend over $1900 on this kit, i need to know more info and what they mean. I understand i can still pass emissions if i set almost everything back to factory settings.
Old Aug 10, 2002 | 12:58 AM
civic23g's Avatar
Look how much bigger and harsher the lobes are on the skunk than a type R one.And that is a skunk2 stage 1 cam,I think most Jun's are prolly even more aggressive.
Old Aug 11, 2002 | 10:41 AM
Tweakmeister's Avatar
Default Re: I have a question about Jun Camshaft kit Stage 1,2,3 (civic23g)
to put it plainly - agressive means it's moving the valves more violently. if you look on the lobes on those cams it's keeping them depressed longer and then dropping them really quickly.
you'll need good valvesprings to keep from slamming your pistons into your valves, and maybe a better timing belt. keeping them in spec, dyno tuned, and fresh oil are all key to longevity.
ahemming06
14
Jul 11, 2006 07:59 AM
kornerk12
Jun 3, 2006 09:43 PM
austrian type-R
Jul 2, 2004 05:20 AM
google
Feb 7, 2003 05:43 PM
ajchen
Dec 19, 2002 11:25 PM
