98 civic CHECK ENGINE LIGHT FLASHING
Old Feb 16, 2009 | 07:57 PM
alfiler's Avatar
New User
Default 98 civic CHECK ENGINE LIGHT FLASHING
my car was running fine after i had changed the spark plugs, and cap and rotor, then the next day i was driving on a rainy day and then the check engine light came on, then the check engine light started flashing, then the speedometer started jumping up and down, and all the electrical lights seem to dimmer on and off. can someone please give some tips on how to fix this problem? thanks.
Old Feb 16, 2009 | 08:02 PM
ifIexplode's Avatar
Default Re: 98 civic CHECK ENGINE LIGHT FLASHING
A blinking check engine light usually indicates a misfire code.
Check the FAQ about jumping the service connector to pull the codes.
Old Feb 16, 2009 | 08:50 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
its your motor saying to you, WHAT HAVE YOU DONE!?! YOU CHANGED ME NOW IM GOING TO SELF DESTRUCT! hehehe...sorry its late...
Old Feb 16, 2009 | 09:14 PM
mortificationrock's Avatar
First things first. Read the codes and find out what they are. There is a Cel Faqs at the top of the forum. After you do that and have the codes check what they are and get back to us if you cant figure it out.
Old Feb 16, 2009 | 11:38 PM
sublime423's Avatar
what kind of plugs?
Old Feb 16, 2009 | 11:40 PM
99EK-T's Avatar
Iv seen the CEL flash before but never dim all the lights, check it out im interested what caused it
Old Feb 16, 2009 | 11:42 PM
alfiler's Avatar
New User
ngk platinum plugs
Old Feb 16, 2009 | 11:55 PM
sublime423's Avatar
if it never happened before the "tune up" recheck your work. tight connections, plug gap, ect...I have seen cheap caps and rotors cause headaches before
03djmAccrd
15
Sep 25, 2010 04:33 PM
aspire
Jun 28, 2010 10:49 AM
Ed 341
Mar 8, 2006 02:45 PM
TurboTurtleGSR
Sep 21, 2002 08:26 AM
