EF or EG shift linkage?
Old Feb 16, 2009 | 06:17 PM
dsnONE's Avatar
Icon6 EF or EG shift linkage?
i went to check out an eg hatch today to possibly buy it, i noticed something funny, the shifter was cocked way forward, i pulled it down thinking it was in 3rd gear or something but it was in neutral.. i immediately notcied someting was funny there so i squeezed the shift boot to see if there was someting underneath and to my surprise it felt like the rubber boot that comes with those 4psd ef's.. is there a difference between ef and eg shift linkages that would make the sifter sit cocked all forward?? i should know this but im confused..
Old Feb 16, 2009 | 06:21 PM
T3KNiQe's Avatar
Default Re: EF or EG shift linkage?
Maybe somebody threw in a dual bend short shifter? Why don't you just look?
Old Feb 16, 2009 | 06:45 PM
dsnONE's Avatar
nah its definitely not a short shifter, and 1st gear is wayyy too close to the console, 2nd is where 1st should be (on a stock shifter setup) and so on and so forth.. its just too far up. i forgot to mention its a z6 motor not a b series so it cant be an integra linkage either..
Old Feb 16, 2009 | 07:00 PM
dsnONE's Avatar
can anyone interject? lol
Old Feb 16, 2009 | 08:29 PM
White95SiHB's Avatar
perhaps it's a modified shift linkage?
I have a B series in my 95 hatchback, with a shift linkage from a del sol VTEC. It had to be cut, shortened and welded in order to fit. When in 3rd, it looks like it's in first. 5th looks like it's in 3rd. Oftentimes while on the freeway I'll put the car in neutral and shift to 5th just to be sure.
I got a B-series shift linkage, but will a stock shifter from a D16Z6/EJ1 fit?
Old Feb 16, 2009 | 08:39 PM
iwanttokillgod's Avatar
perhaps the shifter was installed backwards see it happen a few times
Old Feb 17, 2009 | 04:29 AM
dsnONE's Avatar
After thinking about it I wondered if there was a possibility that it was installed backwards too.. Ef linkages are shorter than eg's, but I'm still stuck on why the hell is that 4spd rubber boot on there! Lol.
Old Feb 17, 2009 | 08:33 AM
94EG8's Avatar
Seagull Management
Thats normal, they all have that. Its to prevent exhaust fumes from entering the car, it also cuts down on road noise and prevents excessive heat from the exhaust from coming up around the shifter.
Old Jun 19, 2011 | 10:10 AM
Joker66's Avatar
i got a question and my bad for post it on here., i got a B Series Linkage Shifter after market for a (ef) can any1 tell me if i can use it on a b series swap for a eg? thanks and my bad for post it in here.
fortillian
Apr 3, 2011 08:35 PM
tealjdmcrx
Welding / Fabrication
Feb 21, 2006 10:41 AM
Eg_TypeR
Jul 27, 2005 10:07 PM
*Boostwerks*
May 3, 2005 08:32 AM
Redsun
Jul 9, 2003 08:44 PM
