Cant get door panel back on, noob question
Old Feb 16, 2009 | 02:59 PM
iiPancho's Avatar
Default Cant get door panel back on, noob question
Ok, removing the busted off mirror and trim peices, go my new mirror on. and the plastic sealed back on, now i cant get the panel to pop back on.
should i put it on top first or from the bottom.
Old Feb 16, 2009 | 03:23 PM
Tzer's Avatar
Default Re: Cant get door panel back on, noob question
If I remember right you put the top in first, Due to it has to drop into the window slot a little bit.
I'm sure this is how you removed it. (Unhooked the bottom then the sides and then slid it up and off). Just do the reverse order.
Good Luck
Old Feb 16, 2009 | 03:29 PM
roadsqueegy95's Avatar
ya if i remember right theres a lil lip that has to drop in beside window, its sometimes a bitch, took me like 30 mins first time, but then second maybe 2. gotta love when windows fall off their tracks lol
Old Feb 16, 2009 | 03:31 PM
iiPancho's Avatar
i still cant get it, anyone got a vid
? haha
Old Feb 16, 2009 | 03:37 PM
Tzer's Avatar
If you have that little triangle plastic piece on already remove it. That goes on after you get the panel in. May that's the problem?
Old Feb 16, 2009 | 03:39 PM
bringmyownend's Avatar
You work the top on first, Try going from the mirror back. Or pull the bottam out away from the door so that lip slides over the lip on the door. You can try for 20 minutes and 3 seconds into the 22nd minute it will pop right on. If you opened this thread 2 days ago i would have taken video replacing my window regulator.
Old Feb 16, 2009 | 03:41 PM
iiPancho's Avatar
i dont have the triangle on, my mirror got taken off by a pole, so for right now i had a power mirror laying around and i slapped it on and just left that peice off.
Old Feb 16, 2009 | 03:47 PM
Tzer's Avatar
OK. Try following what "bringmyownend" posted. You just got to find that "G Spot"
A dumb question now.... You do have your window rolled all the way down right?
Old Feb 16, 2009 | 04:40 PM
iiPancho's Avatar
I did, i was just about to quit and it popped right back on.
and i did have it rolled down. [:
that was a huge pain in the ***. but its all wrapped up now. thanks guys [:
crxaddikt
Dec 10, 2014 07:01 PM
X93siX
Jan 30, 2010 05:34 PM
renelovesnike
Apr 8, 2009 09:19 PM
C2daIzZle
Sep 8, 2005 10:01 AM
E-Rok
Dec 16, 2002 06:53 PM
