Help? b18 curiousities
Old Feb 16, 2009 | 02:49 PM
Dkahn18's Avatar
Default Help? b18 curiousities
I just recently obtained a b18a1 block/head. The head has a p75 intake. Im curious as to what its off of. I cant find anything stating directly what its from. If it is indeed obd1, how will i get this obd0 as im wired for obd0.. or what would you recommend doing?
Also id like to get some aftermarket camshafts and camgears for my ls...but i dont see many for them.. will they work the same if its for a b16 or gsr motor? since they are vtec?
Old Feb 16, 2009 | 04:02 PM
D16SiHatch's Avatar
Default Re: Help? b18 curiousities
the obd1 (94-95) and obd2 (96+) b18b1 intake manifolds are stamped p75. if it still has the stock injectors all you have to do is take out the obd1/2 injectors and drop in obd0 ones.
as far as cams for the ls the only ones i've heard of, and heard good things about, are jg303 cams.
Old Feb 16, 2009 | 04:16 PM
Dkahn18's Avatar
Well i keep seeing skunk2 cams for sale..they say b16-b18.. doesnt specify much..
Old Feb 16, 2009 | 04:21 PM
Dkahn18's Avatar
also what would u recommend using on my b18a1 i have both p75 and pr4 intake manifolds
Old Feb 16, 2009 | 04:28 PM
D16SiHatch's Avatar
it would have to specify for a b18a/b ls engine. dohc vtec b16/b18 cams will not work.
edit: i would use the newer intake manifold. looks better and i would bet flows a little better too
Old Feb 16, 2009 | 04:39 PM
Dkahn18's Avatar
Well i could only assume vtec cams wont work
Old Feb 16, 2009 | 06:50 PM
93formula's Avatar
you can run it on obd0 if you want, i did in my b18...
Old Feb 16, 2009 | 06:52 PM
Dkahn18's Avatar
Well whats the pros of running obd1? as compared to obd0
Old Feb 16, 2009 | 06:57 PM
93formula's Avatar
more efficient, are you planning on modding much?
Old Feb 16, 2009 | 09:09 PM
D16SiHatch's Avatar
running obd1 allows you many more options when it comes to tuning. if you don't think you'll ever have a need to tune the car, be it for nitrous, cams, turbo, etc, then i would just stick with obd0 and keep it simple.
Old Feb 17, 2009 | 02:10 AM
Dkahn18's Avatar
i do plan on building the motor yes.
waynesumner
Oct 26, 2016 03:17 AM
JokerTypeR
11
Jul 14, 2006 07:26 AM
LSV_REX
19
Feb 13, 2006 05:52 PM
ali_232
Sep 16, 2005 10:03 AM
00BuMSiR
Nov 28, 2002 10:32 AM
