Water leaking into car?
Old Feb 16, 2009 | 11:54 AM
SeraphimKidd's Avatar
Icon3 Water leaking into car?
Hello, recently its been raining a lot here and I've noticed a puddle of water on the drivers side where the feet would rest. I have no idea where it could be leaking in from. I've checked the door and even under the car for a possible hole. Any ideas on how to fix this? Any help would be great because I really don't like having the pacific ocean inside my car.
Old Feb 16, 2009 | 11:56 AM
njn63's Avatar
Default Re: Water leaking into car?
Do you have an Si? If so, check the drain tubes for the sunroof.
Old Feb 16, 2009 | 11:59 AM
killercrx91's Avatar
Yup. and check the gaskets for the taillights to. That's an problem sometimes.
Old Feb 16, 2009 | 12:10 PM
sinepome's Avatar
i get what your trying to do but are you saying there are no drain tubes for the sunroof? because i think you may be misinformed. or maybe i just didnt get your joke?
My car also leaked pretty bad when it rained hard. i put some silicone around my windshield, where it was cracked and missing pieces, and it fixed 96% of the problem.GL
Old Feb 16, 2009 | 05:00 PM
troubledcrx's Avatar
he is saying the drain tubes happen to get clogged; and when that happens the water proceeds to flood into the car. Clean out the drain tubes and problem may be resolved.
Old Feb 16, 2009 | 08:44 PM
Oh no its a DX so no sunroof. I found two holes in the carpet by the pedals today and pressed down by them and a little water came out so I'm going to check that out tomorrow if its dry.
Old Feb 16, 2009 | 10:07 PM
patrickstar's Avatar
i have an si and my sunroof has been leaking too. i was so sad seeing my beautiful seats all soggy and wet. where does the drain tube run from? i got no idea where it is.
hondateg08
Feb 18, 2009 07:58 PM
TigerLy
Apr 29, 2008 05:32 PM
hillsidedrill
May 16, 2007 06:32 PM
swt_666
Dec 23, 2006 08:36 PM
red-crx
Feb 5, 2006 06:07 PM
