integra.LS/GSR evo2 exhaust problem
Old Feb 16, 2009 | 10:43 AM
PTSofR3ASON's Avatar
Default integra.LS/GSR evo2 exhaust problem
im about to buy a 98 integra LS and im going to put a GSR head on it..... on top of that im buying a greddy evo2 exhaust system. There are to kinds of evo2 exhaust kits one goes to the RS/LS and the other goes to the GSR.
Which exhaust kit do i buy the GSR or the LS/RS
Old Feb 16, 2009 | 11:12 AM
mrdeadman's Avatar
They let me pick
Default Re: integra.LS/GSR evo2 exhaust problem
You better not buy the GSR head if you don't know the answer to this question. You are going to **** yourself.
Old Feb 16, 2009 | 01:41 PM
1Point8DC2's Avatar
I bought a evo 2 off some kid for dirt cheap for my gsr and i think it came off of an ls. he took it to a muffler shop and had them extend the mid pipe by 4". I went to put it on my gsr and it's 4" too long. So i would recommend buying the exhaust for whatever chasis your working with. chime in if this is incorrect...
Old Feb 16, 2009 | 04:47 PM
from now on if your not going to help dont reply to this but correct me if mine mistaking i thought this was a website that helps people with honda's and or acura's
Old Feb 16, 2009 | 05:41 PM
matsgsr's Avatar
get the one for the gsr
Old Feb 16, 2009 | 07:58 PM
usd-ls-v's Avatar
there is very little difference if any, i have an ls-v with an ls evo2 cat-back and when i purchased this product i checked the model numbers on the two different systems and it was the exact same. i might be wrong about this but if there is any difference the gsr application is just a tad larger in diamater. the fitment is exactly the same, the platform of the car is exactly the same (94-01) there is no difference what so ever. if you are going with a stock build a smaller diamater would probably be a better application. what i found is that with stock specs- after headers, intake and catback, you loose a little bottom end... its to free flowing, you need some back pressure to keep a good launch. you will have alot more topend.
Old Feb 16, 2009 | 09:27 PM
mrdeadman's Avatar
They let me pick
I am saying that if you don't know something as inane as which exhaust (ls or gsr) to put on your ls you better not be ****ing with anything as significant as lsv.
With that said it depends on the header you are running, not the head. The rest of the posts in this thread are bullshit. If you have an ls header you need an ls exhaust. If you have a 94-99 gsr header you need a gsr exhaust. If you have an 00-01 gsr header you need either an 00-01 gsr exhaust or an ls exhaust.
Old Feb 23, 2009 | 06:47 PM
usd-ls-v's Avatar
This you are wrong about my friend, from top to botton and front to back, all with the exception of the itr, b series exhaust manifolds measure out to be the same as far as bolt up fitment is concerned. pipe sizing and design changed a little from model to model and year to year but from the head to the cat. they all line up, the jdm itr header pipe size is different (2.35-2.50 depending on the year) and does not line up with the factory exhaust... some fitting is needed, in that case you would buy a itr cat and exhaust to make things go together more smoothly.
It's*BOLO!!
Mar 27, 2011 01:10 PM
b20quang
Jun 9, 2009 07:15 AM
Adampops
May 13, 2003 06:27 PM
avividmemory
Feb 23, 2003 04:05 PM
ahcjar103
Jan 2, 2002 07:29 PM
