Is honda bond needed when replacing valve cover?
Old Feb 15, 2009 | 07:13 PM
2k_Si's Avatar
Default Is honda bond needed when replacing valve cover?
i just finish painting my valve cover. i have an all new gasket set ready to install. do i need honda bond in the flat spots by the cams and vtec solenoid? or will i be fine with out any? thanks in advance
Old Feb 15, 2009 | 07:15 PM
Juan_Mitosis's Avatar
Default Re: Is honda bond needed when replacing valve cover?
In any case, just to have the gasket sit still while putting the cover back. But having a tube of honda bond around is pretty much a MUST HAVE if you plan on doing many D.I.Y.
Old Feb 15, 2009 | 07:18 PM
steveo135's Avatar
got myself a tube
I would suggest it if your installing a new gasket... but you can always wing it and see what happens
Old Feb 15, 2009 | 07:33 PM
2k_Si's Avatar
would this be ok to use
Old Feb 15, 2009 | 07:46 PM
Targa250R's Avatar
be professional
Gray RTV will work in a pinch. You just need a small dab at any "corners" on the gasket, i.e. the angle on each side of each cam hump.
I use Honda Ultra Flange Sealant myself. Comes in a bigger tube than Hondabond HT and works the same.
Old Feb 15, 2009 | 07:52 PM
2k_Si's Avatar
thank you H-T. i will be going to oreilys tomorrow. i was hoping to finish my weekend project, but i dont want to cut corners
Old Feb 15, 2009 | 09:19 PM
wite2nr's Avatar
yes, I just did a valve adjustment and whenever you pop off the valve cover make sure the surface is clean and free of oil, and put a strip of RTV / hondabond on the corners and by the cam
Old Feb 16, 2009 | 12:01 AM
trustdestruction's Avatar
It's recommended but i've never done it. No leaks here... but I could just be lucky.
Old Feb 16, 2009 | 07:03 AM
steveo135's Avatar
good for you... now i just wish everyone else who considers themselves a DIY'er would practice that
20ls01
Aug 28, 2007 03:49 PM
MugenHonda
Dec 29, 2002 12:35 PM
GSR44
Jun 20, 2002 10:14 PM
nerdish
May 1, 2002 11:48 AM
eTec
Apr 15, 2002 08:27 PM
