91 Accord camber issue
I have a 91 accord 4 door. I have a wicked tuning camber kit in the back thats good for -3.00 to +4.50 degrees and a megan racing toe adjuster. and in the front i have the ball joint looking things that you put on the control arm. but front camber is still an issue.
Has anyone tried using a skunk2 control arm? if so wich one. or does anyone know of a company that makes one.
How low are you? And why would you possibly need to correct that much camber? Sounds like you may have bent parts or something at that point.
There is no replacement upper control arm for accords, it's either the ball joint or anchor style.
IE: Ball Joint type outboard and Anchor Bolt type inboard.
The man (MuffinMan) man is correct however. Even at near-submarine levels, I've never seen the need for such a range of correction. Something is obviously very wrong
P
russianswty
Mar 9, 2007 10:26 PM
EF9SIRJeff
May 31, 2006 04:35 PM
slipstream
Aug 16, 2005 01:56 AM
