intake mani question
Old Feb 15, 2009 | 05:59 PM
Dkahn18's Avatar
Default intake mani question
I just recieve a b18 motor and i was told it had the b18 obd0 intake mani on it. but it doesnt look to be so.. its stamped p75..any ideas?
Old Feb 15, 2009 | 10:15 PM
D16SiHatch's Avatar
Default Re: intake mani question
sounds like a 94+ b18b intake manifold. atleast obd1, could be obd2.
Old Feb 16, 2009 | 02:07 AM
Dkahn18's Avatar
hmm so what all am i going to need to convert to obd1..im swapping this is my 90 civic.. its already mpfi. Ill need an obd1 dizzy and computer right? and jumper harness?
Old Feb 16, 2009 | 11:47 AM
D16SiHatch's Avatar
yep. you can use an obd1 pr4 or p75. and you will need a 4 wire o2 if one isnt already attached to your engine.
Old Feb 16, 2009 | 11:58 AM
allgo88's Avatar
you dont have to go to obd1 just because the mani is obd1.just transfer the wiring.you can also use a obd0 mani and go to obd1.
Old Feb 16, 2009 | 02:04 PM
Dkahn18's Avatar
This guy is swearing up and down its an obd0 manifold.. i dont know tho.. and what u mean transfer the wiring? Use the obd0 injectors?
Old Feb 16, 2009 | 03:49 PM
D16SiHatch's Avatar
yea just use obd0 injectors, obd0 diz, and an obd0 pr4. whether the intake manifold is from an obd0 or obd1 car doesn't matter.
and here are both intake mani's so you can figure out which one you have..
obd0
obd1
Old Feb 16, 2009 | 06:15 PM
allgo88's Avatar
if its obd0 it will have a diaphragm by the throttle body.
Old Feb 16, 2009 | 06:33 PM
Dkahn18's Avatar
obd0
obd1
Ill get pictures up because it doesnt look like either of those
Old Feb 16, 2009 | 06:40 PM
Dkahn18's Avatar
So what would be the benifits of turning everything to obd1 as opposed to obd0?
Old Feb 16, 2009 | 06:52 PM
93formula's Avatar
more efficient, but if your not modding much just stick with obd0.
KDvtec5757
May 12, 2009 11:54 PM
Dkahn18
Feb 18, 2009 04:41 PM
dragaholic
Jul 9, 2004 10:12 PM
Civic Hx-T
May 3, 2004 03:40 PM
