need help skunk 2 springs or skunk 2 coilover?
Old Feb 15, 2009 | 05:01 PM
B16aCRXSi's Avatar
Default need help skunk 2 springs or skunk 2 coilover?
like it says i just braught the skunk2 sport shocks, and i was wonderin which is better? performance wise? either the skunk2 lowering springs or the skunk2 sleave coilover, i know the difference i know that you can at the most get a 2.5 inch drop with the springs, and over 3-4 inchs with the just the coilover sleave, but i want a good ride no bumpy ish, and great cornering, now the sleave coilovers are stiffer, and they are the race springs, so just let me know what you guys would do, springs or coilovers
Old Feb 15, 2009 | 05:08 PM
tacpsi's Avatar
Default Re: need help skunk 2 springs or skunk 2 coilover?
do the lowering springs.....with the coilovers you will get a good straight and corner ride, but but but as soon as you get into some bumps all you will get is klunking......with the springs the are tight to the tower and good corners, straights and a more cumfortable ride, the coilovers were originally made for the track(smooth) ...IMO get the springs you will be more satisfied
Old Feb 15, 2009 | 05:09 PM
jimmy o.'s Avatar
i would get the springs as they ride way better than the coilovers do. I have coilovers on my car and my friend has springs on his both skunk2 of course and stock struts as far as i know
Old Feb 15, 2009 | 05:15 PM
B16aCRXSi's Avatar
but this is the thing, i have a b16b CTR motor in my EG6 and im gonna be going to the track a lot, some dyno time, but then again i have a new born daughter and shes gonna be in the car, now my question is how are the straight springs on the track?
Old Feb 15, 2009 | 05:31 PM
B16aCRXSi's Avatar
anyone
Old Feb 15, 2009 | 05:47 PM
B16aCRXSi's Avatar
still nobody?
Old Feb 15, 2009 | 06:06 PM
dominicanboi215's Avatar
ill stay with the lowering springs y u ask because of the ride comfort... coilovers juz klunk too much and very uncomfortable wen u gonna ride the car for a while i got on my car skunk2 lowering springs with tokio it i spelled it right lol studs and the car drive amasing wit crazy *** resaults on and off the track
Old Feb 15, 2009 | 06:15 PM
B16aCRXSi's Avatar
sounds good, and what do you guys think about the top hats from skunk 2 to go with the skunk 2 sport shocks?
Old Feb 15, 2009 | 06:22 PM
there good but wen u tend to brake hard they bounce dont noe y also like i say sumtimes is good mixing it up a lil if u understand like me skunk 2 lowering spring with tokio struds u can do that im tellin u is nice and it all depend on ur spring compression weight wat is it?
Old Feb 15, 2009 | 06:25 PM
EGhatchguy's Avatar
i have the springs and shocks you are talkin about honestly just use your stock top hats the struts are already designed for less travel and the stock top hats are more than sufficent to do the job. overall i believe the springs will work best since your car is not solely a track car. they still have stiff rates and should do fine at the track
Old Feb 15, 2009 | 06:28 PM
yea stock sus. with stiffer lower spring will give u a more aggressive look with good ride quality and also better performance
Old Feb 15, 2009 | 06:29 PM
B16aCRXSi's Avatar
well i already ordered the skunk2 shocks, they will be here on the 19th, and as far as spring compression rate i wouldnt know its the skunk2 lowering springs for 92-00 civic and 94-01 integra, my just has a b16b CTR motor, full interior gonna get some end links its a lil wobbly in the rear
Old Feb 15, 2009 | 06:33 PM
hey then by all means put it and enjoy because is not bad im just sayin and u need to remember mix things up puttin matching **** in ur car is not always the best thing to do
Old Feb 15, 2009 | 06:39 PM
B16aCRXSi's Avatar
mybad i was just sayin, you got any pics of your cars stance with that setup
Old Feb 15, 2009 | 06:49 PM
ok i dont got pic but the stance is nice not too low
Old Feb 15, 2009 | 07:16 PM
B16aCRXSi's Avatar
word, anyone got a pic of skunk2 sport shocks and skunk2 lowerin springs? just want to see how it sits
Old Feb 15, 2009 | 09:22 PM
wite2nr's Avatar
i had skunk2 springs and skunk2 shocks on my DA... tucked blades in the rear. it was kind of a rough ride. I now have ksport coilovers on my eg and it is a lot smother and just as low. ride quality is subjective, and also has a lot to do with the spring rates. what are the spring rates on the s2's? my ksports are 12k f/ 10k r and it is stiff, but I like it. paired w/skunk2 LCA and ASR brace right now.
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
markers
Honda Civic (2006 - 2015)
Jan 30, 2009 07:49 PM
ZOMBIEKILLER
Mar 3, 2008 03:23 PM
NSUCHOP302
Mar 8, 2005 11:12 AM
one slow coupe
Jan 23, 2005 11:15 AM
