92 accord self locking bolt
the axle should be able to come out thru the fork with out removing. try it i usually spray some silicon spray on the inboard boot and slide it out with no hang up's
Like this guy said, the fork doesn't need to come out.
17mm nut on lower ball joint
36mm axle nut
Remove ball joint from control arm.
Remove axle from hub.
Remove axle from transmission and/or halfshaft.
Move knuckle over and pull axle out through the fork.
Shouldn't take longer than 30 minutes if using hand tools or 10 minutes if using air tools.
Ammadien
15
Jul 14, 2006 05:00 PM
