built b16a2 head p&p unused
ok i have a b16a2 head off 00 civic that originally had 84,000 miles heres what its got.
p&p and 5 angle valve job
brand new type r valves and springs and new valve guides
gsr cams used-have been measured and are in factory specs with practically no wear. and come with gears.
gsr felpro gasket kit everything is the same except im gasket and water outlet gasket
new lost motions
cam caps
dizzy
gsr valve cover
i have the original rockers and also i have the rockers from the head that the cams came from there both used and look the same as far as wear. but your choice on which ones you want. i was planning on using the gsr rockers.
comes with all bolts and also new dowel pins.
this head comes with everything you need EXCEPT the water outlet and gasket and the im gasket.
im aware that i need pics and i will have them soon so bare with me. i have a lot of money in this so give me decent offers. the p&p and valve job alone was 900 bux.
new lost motions
cam caps
dizzy
gsr valve cover
blk1stgen
Honda CR-V & Element
Jan 18, 2014 10:58 AM
