H22 del sol
Old Feb 15, 2009 | 10:24 AM
markspan6243's Avatar
Flattery Will Get You Everywhere
Default H22 del sol
alright im wanting to swap my d series for an h22 but i dont know exactly what needs to be done. what parts will i need and/or what modifications would i need to do to my engine bay if any? any help is appriciated. thanks
Old Feb 15, 2009 | 12:10 PM
trustdestruction's Avatar
Default Re: H22 del sol
idk the answer, but to help your search out, it'll be mostly the same as swapping an h22 into an EG
Old Feb 15, 2009 | 01:16 PM
94_DC's Avatar
The left side of the engine bay has to be pushed in since the motor dosent clear. The hood has to be lifted alot since the valve cover wont clear the engine bay. Custom shift linkage since its going into a del sol.
Thats all that I know.
Old Feb 15, 2009 | 05:48 PM
dropped_dime98's Avatar
Assuming the swap will be like an eg swap then:
You need to get some motor mounts for the H22 Hasport or Avid mounts (i went with Avid) since you dont have to cut off the stock mount so there is some hope to going to a B or D again.
You can run the basic cable shift linkage no problem youll just have to cut a hole in your floor to run the cables.
As far as clearance goes, i dont have a problem with the hood closing not did i have to do any modifying to the engine bay for it to fit. Its an almost tight fit but there room to do some work. Only thing i had to do was relocate the fuel filter. This is on an eg though but i assume there isnt much engine bay differences but could be wrong.
9k Swag
Aug 11, 2011 07:18 PM
banduondubs
Oct 18, 2006 11:50 AM
musifuger
Mar 15, 2005 08:25 PM
cjnc22
Mar 15, 2004 12:42 PM
DELshow
Dec 27, 2003 01:20 PM
