Super high RPM when i turn on my car
Old Feb 15, 2009 | 09:42 AM
FRKWOO's Avatar
Default Super high RPM when i turn on my car
everytime i start my car now the rpm shoots to 2000 and stays there for a bit then slow dropps after about 2-3 mins and its been doing this just recently about 2-3 weeks ago and it wasnt doin this before and i was wondering what is causing this to happen and if it is normal??? thanks h-t!
Old Feb 15, 2009 | 09:50 AM
grandtheftlunchbox's Avatar
Default Re: Super high RPM when i turn on my car
What's your idle speed at normal operating temperature? Your idle air control valve (IACV) or your fast idle thermo valve (FITV) may need to be cleaned out. the IACV is located behind your throttle body, try that first. spray some carb cleaner into the holes and that should take care of most of the carbon build up in there. if that doesn't work, there is a thread somewhere that tells how to clean out a FITV, but many mechanics replace them because they're relatively cheap.
Old Feb 15, 2009 | 10:00 AM
FRKWOO's Avatar
ive cleaned it already
Old Feb 15, 2009 | 10:11 AM
95vxtealhatch's Avatar
Idle up on start up is normal, my engine revs to 1.5-2k when i start it depending on temp, and i consider my engine to be running in tip top shape. If it warm idles @ 2k then you have a vac leak, otherwise just leave it alone.
Old Feb 15, 2009 | 10:21 AM
JDM Hunter's Avatar
its normal bro, dont sweat it.
the weather also plays a big deal in it
Old Feb 15, 2009 | 10:30 AM
FRKWOO's Avatar
thanks guys!!!
Old Feb 15, 2009 | 10:38 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Normal.
josh devera
Jan 9, 2018 04:38 AM
2low93
Feb 17, 2012 04:13 AM
TearSDMF89dx
Jan 3, 2012 04:31 AM
Thagoldenb
Jan 5, 2011 05:12 PM
wickedxboi
Nov 9, 2002 12:39 PM
