sohc header, how much difference?
Old Feb 15, 2009 | 07:15 AM
s1mplifly's Avatar
Default sohc header, how much difference?
i dont know if ill get in trouble making new threads with similar questions but here we go anyway, if i get a megan racing header for my d16, how much power difference will it do? or if there is any difference at all.
Old Feb 15, 2009 | 07:17 AM
joshkx's Avatar
Default Re: sohc header, how much difference?
its will improve a bit..... but not that much....like 1-5 hp depending
Old Feb 15, 2009 | 07:20 AM
s1mplifly's Avatar
oo i c thnx
Old Feb 15, 2009 | 07:39 AM
s1mplifly's Avatar
oh and i was wondering if any of you guys know how much is it for the labor to replace the header because i doubt i could do it myself.
Old Feb 15, 2009 | 07:42 AM
Hill4589's Avatar
If you have tools you can do it for sure.. dont think anything is too hard my man
Old Feb 15, 2009 | 07:57 AM
6footmidget's Avatar
its super easy! the only hard part is if you dont have a jack then youd have to find one or buy one
Old Feb 15, 2009 | 09:47 AM
random chaos 85's Avatar
or you can just dig a hole in the ground to work in and drive over top of it. i prefer takin it to my shop and puttin it up on the lift tho.
anyway, which d16 are we referring to here? z6? y7? y8?
Old Feb 15, 2009 | 10:00 AM
s1mplifly's Avatar
its a y7 , and i have a jack, can you guys explain basic steps to do it if its not too much trouble
Old Feb 15, 2009 | 11:46 AM
socallmechris's Avatar
sure:
1. jack up the car. if you have jack stands, use them.
2.if you still have a splash shield under the front of the car(i dont) remove it or just pull it out of the way.
3. make sure the exhaust it cool to the touch so you dont burn yourself and locate everything holding it on. there should be 2 spring bolts at the cat, two nuts on a hanger behind the oil pan, and like ten nuts at the exhaust flange. i think there also might be one in the front/bottom of the block, this one can be completely removed because your new header will not have a hanger there.
4. remove all the nuts/spring bolts and put them in a little magnetic tray so you dont lost them. "i was too cheap to buy one, so i have a blown subwoofer magnet on a small cookie tray lol"
5. the factory mani is two pieces, but i never had to undo the center portion. just make sure the car is up high enough and drop the whole thing out the bottom. it is gonna take some wiggling and cursing but it does fit.
6. your new header is probably also a two piece design, if not ignore steps 7 & 11. put the new exhaust mani gasket(prob came with the header) on the studs and slide the top portion of the hearer on after. put the nuts back on so it doesn't fall off, but leave them loose for now.
7. back under the car. the center portion has its own gasket(or at least it should) put the gasket between the two halves and install the three (new)bolts that hold the section together. again leave them kinda loose for now
8. bring the end of the header to the cat. it should have a donuts style led gasket. put that on the end and stick it to the cat. spring bolts can be a pain in the dick sometimes but throw those on there now
9. if the header has a spot for the hanger with the two nuts, put that on now. if it doesn't, **** it, you dont need 'em.
10. tighten the manifold nuts so it seals real good. there is always that one that is a pain to get to cuz there is a tube in the way. dont get discouraged, just curse alot and keep at it. a swivel helps
11. tighten the center three bolts so that its nice and tight
12 put up you front engine splash(if you have it)
13. with the car back on the ground, let it run for a while. this will let you hear/see any leaks. alo of time the coating on the header will start to burn off now, dont worry your car is not burning down when you see a little smoke, just keep the hood up for now
14. shut it down, let it cool off and check for leaks at the gaskets. if you find a leak, tighten the nut/bots accordingly
15. no leaks? do a burnout.
Old Feb 15, 2009 | 11:53 AM
trustdestruction's Avatar
it'll be more like 2-3hp
Old Feb 15, 2009 | 01:31 PM
mechanix619's Avatar
You can do it yourself, its a really easy job. All you need is basic tools, jack stands, and a jack. Give it a shot. It'll probably be a little time consuming because it's your first time tinkering with the car but you'll never know until you try.
Old Feb 15, 2009 | 02:08 PM
green99civic's Avatar
I think it will be within somewhere within 3-5 hp and it will be at higher RPM like 4000. I would get a Catback if you go with the header that way you gain a little of your mid range back.
Old Feb 15, 2009 | 07:42 PM
s1mplifly's Avatar
thnx guys help me out, im going to order the headers this week and hopefully i do the job right
Old Feb 15, 2009 | 07:54 PM
ek coupe's Avatar
wow your joking right!!!?
Old Feb 15, 2009 | 07:59 PM
s1mplifly's Avatar
im pretty sure im not joking.
Old Feb 15, 2009 | 08:03 PM
ek coupe's Avatar
my two year old brother could do it! come on now! it doesnt take a guience to figure this out!!!
Old Feb 15, 2009 | 08:06 PM
s1mplifly's Avatar
im pretty sure not everyone in the world is implanted with car knowledge and it is just i dont want to fck it up and do a bad job, and im also sure that your two year old brother wont be able to do it.
Old Feb 15, 2009 | 08:47 PM
in the switchover to vbulletin half of the thread was gone. it should still help some though.
http://www.hondacivicforum.com/forum...ad.php?t=53265
Old Feb 15, 2009 | 09:17 PM
wite2nr's Avatar
its pretty easy and straightforward to install a header. also, set aside $80 for a new O2 sensor before you get started because the stock one might be siezed in the OEM header.
Old Feb 16, 2009 | 05:37 AM
s1mplifly's Avatar
thnx for the help guys, unlike others *cough cough ek_coupe cough* lol
Old Feb 16, 2009 | 05:40 AM
Mr. Huskie's Avatar
Let us know the results!
Old Feb 16, 2009 | 05:41 AM
EJ8freek's Avatar
Yeah, not that much. About 1-2 horsepower.
Old Feb 16, 2009 | 06:03 AM
brutekiller787's Avatar
you're also gonna throw a cel because your catalytic converter (needed to pass inspection in most states) is in your header, so if you replace your header, you will not pass inspection. i would suggest converting your entire exhaust to EX spec (seperate header/ converter) and getting an o2 sensor extension from passwordjdm
Old Feb 16, 2009 | 07:11 AM
s1mplifly's Avatar
this morning my dad actually told me not to replace it since in 2 years my engine will probly break down, he said just to wait and get a whole swap instead. so im just going to save money and get abetter engine with all the other parts.
Old Feb 16, 2009 | 08:19 AM
well still i would get your exhaust system and cat now, since i'm 99% sure they are body-specific instead of engine-specific like a header is. then if you do get an ls swap for instance, you will be able to bolt it right up to your existing exhaust. if you look hard enough you can find a ws2 for under 400 and a magnaflow cat with flanges already welded on for under 120
