H22 Catch Can
Old Feb 15, 2009 | 06:42 AM
BrowNKiD's Avatar
Default H22 Catch Can
Hey I was thinking of purshacing a T1 Catch Can to put on my H22. I just have a few questions. I know that on a bseries four fittings goto the valve cover and 2 goto the back of the block. But on an h-series where do the ones for the block go because an h22 doesnt have a pcv box on the back of the motor?
Old Feb 15, 2009 | 07:50 PM
B R Fittings's Avatar
Default Re: H22 Catch Can
On the h22 you just use one drain back. A line going from the side of the catch can located on the bottom, to the oil pan. So you will need to weld a -10 bung on the back side of your oil pan. Then you can have up to 4 lines on the valve cover going to the catch can.
Old Feb 15, 2009 | 07:51 PM
jlude90's Avatar
i think a -10AN line is a little bigger then necessary, no?
Old Feb 15, 2009 | 07:57 PM
I wouldn't go anything less then a -10. Its not overkill at all.
Old Feb 16, 2009 | 07:50 AM
BrowNKiD's Avatar
Thx for the help does anyone have any pics of this done on there h22?
Old Feb 16, 2009 | 08:03 AM
H22JEFFREY's Avatar
I have a t1 complete catch can for sale from my h2b part out if interested,
Old Feb 16, 2009 | 08:27 AM
jlude90's Avatar
hrmph, i wasnt aware the drain line needed to be that big
Old May 4, 2009 | 04:25 PM
megomaniac's Avatar
what if you use the bolt for aligning the rear balance shaft, as a location for drain back, anybody tried this? (on the back of block, used in service manual when installing balance shaft belt)
using this fitting -8 to 12mm x 1.5
http://store.summitracing.com/partde...5&autoview=sku
Old May 5, 2009 | 03:52 PM
megomaniac's Avatar
bump
Old May 5, 2009 | 08:13 PM
jlude90's Avatar
i'll tell you what, take that bolt off and turn your engine on, let me know if you want that to be a hole that your oil will gravity feed down to.
heres a hint, it shoots oil out EVERYWHERE. i don't think it'd be a good spot for it. i'd say try the oil heater spot before that.
Old May 5, 2009 | 08:23 PM
megomaniac's Avatar
okay , where's the oil heater??? (joking)
tang2kiwi
Oct 4, 2011 12:49 PM
huskyl3oi
May 16, 2010 07:15 PM
h22crxpwr
Dec 8, 2008 09:52 AM
accrd18
Nov 25, 2006 08:16 PM
EDANSiR
Sep 13, 2006 05:36 PM
