problem swap tranny 6speed in 6th gen av6
Old Feb 15, 2009 | 05:20 AM
conge08's Avatar
Icon2 problem swap tranny 6speed in 6th gen av6
Hi guys,
I'm already done with swap tranny from 04 accordv6 6speed into 98 accord v6 and my vtec not working,I get limited rev becouse I get the problem with vss sensor from 04 accord 6speed they use three pin on the sensor and my auto tranny factory vss sensor use two pin on sensor,
Anybody have done with this problem?what a kind vss sensor use two pin which one can fit with my wire.Please give me advice and I really appreciate that. Thanks everyone.
Old Feb 15, 2009 | 07:58 PM
conge08's Avatar
Default Re: problem swap tranny 6speed in 6th gen av6
bump....
No one knows about this???????????
Old Feb 15, 2009 | 10:47 PM
Patman's Avatar
Can you get any sort of a wiring diagram that explains what pin does what for each connector? Sounds like the difference is the 04' model uses the 3-pin and one might be a ground as opposed to the 98 uses the 2 pin and the tranny itself is grounded. Let us know
Old Feb 16, 2009 | 04:50 AM
conge08's Avatar
The problem I don't have wiring diagram for 04 model but I have for 98 model,may be you right but I'm scared if I hook up 2 pin together and 1 as ground and connect to my factory wiring it will be damage my ECU bc I don't what does for the 3 pin?
Does any one have or knows about wiring diagram for vss 04 model? I really appreciate it that.
Old Feb 17, 2009 | 10:33 AM
conge08's Avatar
Helloooo........?
No body read this
Old Feb 17, 2009 | 11:38 AM
xci_ed6's Avatar
can you fit the 2 wire sensor in place of the 3 wire?
Old Feb 17, 2009 | 03:36 PM
conge08's Avatar
I don't know about that but I think the 3 pin sensor more bigger then 2 pin, do you have experience about this?
Old Feb 17, 2009 | 03:57 PM
TheMuffinMan's Avatar
He knows where you live!
I have never heard of this swap, just the CL-S to V6 swap. I am curious if the VSS is different on the CL's as well.
Old Feb 17, 2009 | 05:18 PM
conge08's Avatar
Not only cl-s tranny you swap to v6 but any tranny from v6 like accord,tl or cl-s. I don't know if the vss sensor different with cl-s,I get 3 pin on vss sensor from 04 accord, how many pin on cl-s vss sensor you know?
Old Feb 17, 2009 | 05:35 PM
I'm unsure, which is why I posted that. It may be why that gets used as opposed to newer J motors.
Old Feb 18, 2009 | 10:41 AM
jweller's Avatar
swap the 2 pin VSS in and see if it fits/works
Old Feb 21, 2009 | 04:28 AM
conge08's Avatar
thanks guy for all input and I try to put 2 pin sensor and looks is work or not.
F23Da
Oct 8, 2016 06:16 PM
Project_DX
Feb 15, 2007 03:53 AM
hybridpatient95
Acura TL, RL & ZDX
Mar 25, 2006 04:41 PM
4jackstands
Oct 24, 2005 10:26 PM
NeXtLeVeL_TyPe_R
Oct 24, 2002 07:27 AM
