d16z6 in a ej8?
My motor is blew(d16y8). And here in norway and on ebay it is hard to find a d16y8.
I have a d16z6 block from a 1994 ej on hand.
What is needed to get this to work?
fix the ckp sensor into a cky?
Make a hole for the knock sensor?
I'm going to use the orginal top and ECU P2P
Thanks for any reply
if you use the y8 ecu then you will have to bypass the cylinder fluctuation sensor because one is not present on the z6. as far as the knock sensor goes, i think you can just leave that connector unplugged and as is i don't think it will throw a code. i may be wrong and if so someone feel free to correct me lol.
http://ff-squad.com/wp/?p=309
xkrazyxjbrkerx75
Nov 22, 2009 11:43 AM
yz125rider21
Jan 11, 2006 09:39 AM
