Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Clutch Adjustment
Old Feb 14, 2009 | 05:08 PM
integ_lude's Avatar
Default 01 Clutch Adjustment
Hey guys I used to be able to adjust my clutch pedal on my 93 Acura cable tranny I was wondering if there is a way to do this on a stock 01 Civic EX.
I had the clutch replaced and its fine but it grabs a little past half when I release is this normal? I like my clutch to grab right when I release that way I do not feel like I am riding it.
Any tips?
Am I just being ****?
-Thank you
-Logan
Old Feb 14, 2009 | 11:20 PM
toyomatt84's Avatar
Sanji
Default Re: 01 Clutch Adjustment
Bleed the clutch line at the slave cylinder.
Old Feb 15, 2009 | 09:20 AM
greeen01civic4d's Avatar
there isnt any ajdustment on the 01-05 hydrolic clutch, u can bleed it and see if that stiffens it, but thats all u can do man, sorry
Old Feb 15, 2009 | 02:23 PM
integ_lude's Avatar
Ok I will try bleeding, does anyone have a pic of the slave cylinder? Is bleeding similar to the breaks?
Thanks
Old Feb 15, 2009 | 05:47 PM
integ_lude's Avatar
Disregard last update of mine it was a newb question I just went to google and searched. It seems like a easy job I will have my wife pump the clutch tomorrow.
Old Feb 15, 2009 | 06:04 PM
Targa250R's Avatar
be professional
Any tips?
Hydraulic clutches are not adjustable. The only adjustment is pedal freeplay, which doesn't serve the same purpose as adjusting a cable clutch. You don't want to touch the pedal freeplay adjustment because it will never be right again.
A properly bled hydraulic clutch will start out catching slightly above halfway pedal travel when new, and get higher from there as the disc wears.
Jdmkdmkid
May 5, 2013 06:45 PM
tigueremalo
Jan 14, 2007 02:29 PM
tnsxsear1
May 18, 2004 09:56 AM
Khmi
10
Mar 15, 2004 12:26 AM
hatch4raceb16
Dec 1, 2003 04:35 PM
