Valve spring sticking???
93 accord LX
I replaced my lower spark plugs and reinstalled everything.
I got a new clicking noice. I rmoved the valve cover and noticed the rocker arm for the left exhaust spring on the #1 cylinder is skewed a millimeter or two to the right off center of the rocker arm. What does this mean, now it seems like when I crank the engine, that spring snaps back up and hits the rocker arm hard and causes the arm to hit the cam. What would cause this spring to be a little bit crooked?
What do i do?
What do i do?
93 accord LX
What do i do?
What do i do?
If anything got between the head and the spring, that would cause it to tilt as well.
P
P,
Theres nothing touching the spring. it looks like the stem of the valve shaft is crooked, how would this happen. Is this a bent valve. P, you want a picture?
I refer to
[quote] "that spring snaps back up and hits the rocker arm hard and causes the arm to hit the cam" [quote]
It sounds like the upper valve stem has bent and sticks when pushed into the guide. This is opposite what normally happens (normally the valve HEAD bends).
P
a side strike with a hammer or dropping the head could cause this.....
Combustion Contraption
23
Nov 27, 2006 07:59 PM
