dx hatch ?'s
Old Feb 14, 2009 | 03:48 PM
specialized108's Avatar
Default dx hatch ?'s
i need to get a new muffler and i was wondering what the exhaust diamiter was on a 90 dx hatch with a stock size exhaust.
my other question is that my d15b2 has oil in the intake tube and in the throttle body cover area "the plastic thing that says dpfi on it (not exactly sure what this is called). dose anybody have an idea what could be causing this? any input would be helpful.
-thanks alot
joey
Old Feb 14, 2009 | 03:52 PM
sgallagher's Avatar
Default Re: dx hatch ?'s
The exact size of the piping im not sure but its probably 1 1/2" or so.
As for the oil, could be caused by excessive crankcase pressure or faulty pcv valve.
Old Feb 14, 2009 | 03:59 PM
the oil situation is really confusing me due to the fact that i have a breather on the valve cover, so i really dont understand how the oil is getting all the way up there because the only thing that could be letting oil into it is the pcv valve that is all the way down on the intake manifold runner
Old Feb 14, 2009 | 04:56 PM
sgallagher's Avatar
Could be residual from when there was no breather...
The hose from the valve cover to the intake tube allows vapors and a small amount of oil to enter the intake tract which is normal. If everything is coated in oil that is excessive and there is a problem with the system.
Old Feb 14, 2009 | 05:05 PM
93formula's Avatar
change the pcv and put everything back to stock theres no need for fancy breathers especially on a dpfi...
Old Feb 14, 2009 | 06:45 PM
jhammond_82's Avatar
Reject Papi
lol
Old Feb 14, 2009 | 07:26 PM
shyguy4no1's Avatar
don't feel bad... I have an 89 dx and I am suffering from the same problem... dpfi (if you haven't been told) means you have direct port fuel injection (you have 2 injectors per cylinder) you (like me) probably want mpfi (multi port fuel injection) 4 injectors per cylinder. But in the end its your choice. Just be fortunate that you are not in cali with carb regulations. Its annoying but I am making due. Good luck in your work on your engine though. Seriously.
Old Feb 14, 2009 | 07:35 PM
Reject Papi
2 injectors per cylinder? 4 injectors per cylinder? you mean you currently have 2 injectors for 4 cyl. and you want 4 injectors for 4 cyl? i hope thats what you mean, or you deffinately have to take a trip to the FAQ!
Old Feb 14, 2009 | 07:51 PM
shyguy4no1's Avatar
OOPS... I missquoted... my bad...
Old Feb 14, 2009 | 07:56 PM
93formula's Avatar
lol this thread deffinately gave me a chuckle tonight.......
Flux
May 9, 2004 10:33 AM
jdmgeorge
Feb 10, 2004 06:55 PM
nerdsports
May 10, 2003 11:47 AM
GruvyTune
Oct 22, 2001 01:29 PM
