can i put a h22 a/t in my 92 accord
Old Feb 14, 2009 | 09:03 AM
colter24's Avatar
New User
Default can i put a h22 a/t in my 92 accord
i would like to put a h22 a/t swap in 92 accord can it be done
Old Feb 14, 2009 | 09:10 AM
cb9tuner's Avatar
Default Re: can i put a h22 a/t in my 92 accord
yea it can its a direct swap just need to add all the vtec wiring
Old Feb 14, 2009 | 02:39 PM
xhondaaccord92x's Avatar
yes it can... thats what i have done but im stuck cuz i need an tunable ecu to use and cant find any real chips for the auto cuz the p13 has to be used. i have a very built n/a motor and only a apexi neo to tune it all
Old Feb 15, 2009 | 08:40 AM
Speedfiend97LX's Avatar
Theres a little more to it than just adding the vtec wires but its fairly easy to do if you do your research and have the right tools. I did the H22 swap into my 92 so let me know if you have any questions.
Old Feb 15, 2009 | 09:07 AM
r u looking to keep a/c or p/s? vtec wires and knock sensor need to be added and ran to ecu...not hard. a p13 ecu and prelude tcu for trans is needed.. keepin it auto it has to use those computers. use accord axles and mounts. and for any clean install, while the engine is out a engine bay wire tuck is always nice.
Old Mar 2, 2009 | 07:09 PM
mrmoetan's Avatar
New User
I am in the middle of doing this swap to my car and I'm stuck on the wiring. I have a JDM H22 and its going in a 92 Accord. I have most of it done but i'm stuck on the distributor. My harness is for external coil and the motor is internal. I have no clue where to go from here....Any help. Colter, the motor just bolts right in but the wires and vacuum lines get a little tricky.
92DAIntegraXSI
Jan 16, 2009 10:37 AM
pasha99
Feb 13, 2007 07:18 PM
2000R
Dec 6, 2001 05:56 PM
