FS: Civic Integra S2000 Parts..(MI)
s2000 front lower control arms , needs new bushings, perfect candidate for Mugen bushings.. : $100
- D16y8 Sohc Vtec Head - INCLUDES everything, EXCEPT Intake/Exhaust Manifolds & Dizzy. : $120
- EX / SI Transmission : $100
- obd1 sohc Vtec engine harness - uncut : $60
- obd1 Sohc Vtec Intake Manifold w/ TB : $30
- D-series Manual trans Starter 92-00 : $10
- D-series Auto trans Starter 92-00 : $10
- D-series Alternator, Not working (good 4 parts or core exchange) : $5
- D-series Clutch/PP : $20
- obd1 Sohc OEM pulley : $5 (non PS)
- obd1 Sohc Vtec OEM Pulley w/ Key and bolt : $10 (w/ PS)
- obd1 Sohc Vtec timing belt p28 (slightly used): $5
- Civic IACV : $15 each
- Civic Automatic racing peddles : $ 5
- 96+ D Series EK AC bracket (Aluminum) $10
- 96+ D Series Rear T bracket : $5
- B Series exhaust gasket : $1
- 98 Integra LS power steering pump (no brackets) : $10
- Integra GSR Flywheel $10
- Integra LS Flywheel $10
- Integra PP $10
- Integra IACV : $15 each
- Brand new civic/teg Upper A-arm w/ ball joint DRIVER SIDE, never installed : $40
- Civic / Teg Tie Rods, good ball joints : $5 / pair
- 12 volt vacuum pump - used for turbo gsr crank case ventilation : $10
- Resistor box for low impedance injectors : $10
Shipping and PAYPAL not included.. PM for quote..
- Integra PP $10
CALIGUYCRX
May 15, 2012 12:01 PM
allaboutdaz
Jun 3, 2010 08:54 AM
egb16pg
Oct 30, 2009 04:08 PM
