Oversized Piston (friend needs help he's going all motor H22)
ok here's his question
he has a Del Sol with an H22 in it
im going all motor with my prelude H22 motor......... is there any problems i should know of if i bore my block from 87mm to 90mm...... and of course the block is gonna be sleeved
good luck runnin 90mm, you have to notch the sleeves to get them to fit, and it weakens them. Not to mention the side loading of a piston that size your rods will push againt the side of the cylinder instead of on the bottom of the piston. I'd tell him to run 89mm and be done with it. Much safer and the gains from 89 to 90mm would be minimal.
I could be wrong about that, but I have heard it from a few peeps...they had aftermarket rods with the pins moved closer to the rings and they were getting bad marks on the cylinders from side loading.
You can do it (90mm), but be prepared to have to replace head gasket frequently. Based on my experience, I would suggest going no bigger than 89mm. Also with thinner walls, you will get cylinder distortion (cylinder will become oval shaped over time).
You should see the inside of my engine... Very clean Just pulled the head off 2 days ago. 89mm works the best IMHO. The side loading you are talking about in a stock h22a is not nearly as bad as in my stroker, so don't worry too much.
[Modified by 2point6, 10:04 PM 8/9/2002]
What is the piston size with a standard (per factory manual) .020" overbore? (1996 H22A) Would the cylinder still be strong enough for a serious STREET all motor setup (no nitrous)? I've got a scratch in my cylinder I don't think honing will take out.
sadam-insane
Jun 9, 2008 07:02 PM
The_In_Kid
Aug 10, 2002 01:53 AM
