Got a few questions, seats,tps,speedo cable.
Old Feb 13, 2009 | 09:11 PM
tkda's Avatar
Default Got a few questions, seats,tps,speedo cable.
ok i need to know if em1 si seats front and back will fit in my 90 dx hatch.
i got a jdm sohc zc and i need to know how to remove the broken tps and replace it.
and how how to get my speedo cabe out of the tranny.(its automatic but i dont think its different)
thanks a ton.
Old Feb 13, 2009 | 11:05 PM
h224thgensedan's Avatar
Default Re: Got a few questions, seats,tps,speedo cable.
For the tps just take a dremel, hacksaw, or something like that that you can make a groove for a flat head screw driver and make a notch in the ground down part of the head. Just remeber after a tps change ajustment may be needed. Sorry for any typos im a bit drunk.
Old Feb 13, 2009 | 11:38 PM
tkda's Avatar
adjustments on the air/fuel ratio on the intake manifold?
Old Feb 13, 2009 | 11:42 PM
Clipsed's Avatar
no, the TPS has to be mounted properly in the correct position. You can't just throw it on there and expect the car to run properly. Just like a distributor, you have to adjust it, but it will run if you put it on.
Old Feb 13, 2009 | 11:50 PM
tkda's Avatar
what if i put it on in the same position it was in before?
Old Feb 14, 2009 | 12:36 PM
tkda's Avatar
bump, preedo cable needs to come out before i can drop the motor.
Old Feb 15, 2009 | 08:13 AM
there is a little clip that holds it in. Shaped like a u kind of
Old Feb 15, 2009 | 09:51 AM
tkda's Avatar
yeah,,, i needed the motor out so i just yanked real hard..
looks like i will be putting it back together.
crxguy406
20
Feb 6, 2011 08:59 AM
MrXclusivE
Aug 25, 2009 12:05 AM
the-jr-man
Feb 14, 2006 03:24 PM
EFwithS2000taillights
Aug 26, 2005 09:34 AM
.ShawnD.
May 21, 2002 10:45 PM
