H22A throttle responce.
Old Feb 13, 2009 | 05:57 PM
Peeonu25's Avatar
Default H22A throttle responce.
I have a OBD1 96 H22A swapped into a 94 accord with a JDM p13 ECU. (I didn't do the swap)
MSD Blaster ignition coil... bosch plat 2 plugs, I've had spark problems in the past, which i solved by playing with the coil wire. i just put in a walbro 255mlh fuel pump.
I have a apexi vacf2 and it says the TPS is getting the correct voltage from closed to WOT
just replaced the IACV, which helped a lot with the throttle responce
injen intake
dc header, high flow cat, and dc cat back.
if i line the timing marks up on the fly wheel the car runs like crap, so that leads me to believe the car has cams in it.
i have a slight suspicion that its the coil wire, or something to do with the charging system (if thats possible)
Old Feb 14, 2009 | 09:11 AM
Peeonu25's Avatar
Default Re: H22A throttle responce.
bump
SCRUBBAGE2
Apr 17, 2011 11:12 AM
TLo
May 25, 2008 08:12 PM
sprayedlude93
Apr 12, 2006 05:48 PM
WNYAccordLX
Mar 22, 2003 06:12 AM
