JDM cluster to USDM cluster
Old Feb 13, 2009 | 04:51 PM
Will_H's Avatar
Default JDM cluster to USDM cluster
I just bought a usdm ITR cluster.. I removed my jdm itr cluster and installed my usdm itr cluster, now when i start the car both turn signals are on solid and the temp,coolant dont work. the tach seems to work off and on when i would hit the brights the tach would stop working. Is it possible the car has a JDM itr dash harness? Is there a difference between the to harnesses? Thanks in advance
Old Feb 14, 2009 | 03:27 PM
Will_H's Avatar
Default Re: JDM cluster to USDM cluster
anyone??
Old Nov 30, 2009 | 04:30 PM
TriniRacingDevelopment's Avatar
I'm having this same issue.
Can anyone chime in on this?
Old Dec 1, 2009 | 06:06 PM
JNocon's Avatar
Have you guys got a service manual book or the alldata cd for your car? You need to look up the wiring diagram and see if all the wiring are corresponding to each prongs behind the gauge cluster.
Old Dec 1, 2009 | 11:52 PM
fastrxu's Avatar
It was all the same that i knoe of.
Ima double check though
JTTeG_X
May 25, 2009 07:10 AM
GuitarSlinger78
Aug 16, 2008 01:38 PM
JDM_FRONTIN
Sep 14, 2007 09:47 AM
cltitus
Mar 15, 2007 07:41 AM
JasonNagra
Sep 30, 2001 08:14 PM
