Options for usdm B16 block....
Old Aug 9, 2002 | 07:16 AM
one.EG6's Avatar
Default Options for usdm B16 block....
ok, so what can I bore the B16 block out to, or should I even do that? Should I just use a GSR crank? I want an all motor app, and I want it to be strong as hell... with a high CR.
stock bore is 81mm if I'm correct, so what is the possibility there?
also, any other advice is appreciated.
I'll be using a type-R head, and haven't fully decided on internals... maybe keep all the stock R stuff, but use CTR pistons? if I bore it I'll go aftermarket of course, but there are too many ways of doing this...
suggestions? advice? setups?
thanks.
Old Aug 9, 2002 | 07:53 AM
JMinSi2000's Avatar
Default Re: Options for usdm B16 block.... (one.EG6)
Send it to golden eagle and get them to sleeve it and bore it to 84.5mm. It'll be a 1.8 liter then.
Old Aug 9, 2002 | 08:00 AM
one.EG6's Avatar
Default Re: Options for usdm B16 block.... (JMinSi2000)
alright.. that's what I was thinking.. I just didn't know what would be a better route. The resleeve or the bigger crank.
so... golden eagle resleeve, mugen head gasket, CTR pistons, ITR head P&P w/3 angle valve job.. anything to add to that setup? or change? opinons?
thanks.
Old Aug 9, 2002 | 08:03 AM
JMinSi2000's Avatar
thanks.
With an 84.5 mm bore you're gonna need a custom head gasket. I'd give cometic a call and get them to make one with 84.5mm holes and have it be the stock gasket thickness.
Old Aug 9, 2002 | 08:07 AM
one.EG6's Avatar
yeah, you're right.. can't believe I didn't think of that one! add milled head to that list also ^. how much should it be milled?..... .20?
thanks.
Old Aug 9, 2002 | 08:08 AM
JMinSi2000's Avatar
I'm not sure. You may want to enlarge your combustion chamber though and get it to match since it'll be smaller than the bore of the block now.
owen_the_soyboy's Avatar
With an 84.5 mm bore you're gonna need a custom pistons, I do not think CTR pistons are available in that bore.... you need some Endyn rollerwave / Weisco high compression pistons.
if you are gonna rock an ITR head, keep the itr head stock and focus your time, tuning and money on other things... fuel/ecu/bottom end/exhaust/ dynotuning, etc.
the ITR top end is very well tuned and can handle up to what, 9000 rpm? and some setups have made great power up to 9000 rpm with ITR cams.
if you stick with them that saves you a LOT of cash as opposed to aftermarket cams and a necessary valvetrain upgrade if they are big cams... Spec B, Stage 3, etc.
good luck, should be a good project
Old Aug 9, 2002 | 08:12 AM
WAFFLES's Avatar
Default Re: Options for usdm B16 block.... (owen_the_soyboy)
go for the OEM stroker kit. b17 crank and rods with CTR pistons! Great r/s ratio, improved tq, b16 revability. And add a 2 layer headgasket and your set. Pick cam profile to suite your preferneces.
Old Aug 9, 2002 | 08:18 AM
one.EG6's Avatar
Default Re: Options for usdm B16 block.... (WAFFLES)
damn... now I'm torn. Do I resleeve or stroke it? This is the question I started with...
ok, it's always gonna be all motor.. always N/A. I want a very high revving motor with great relibility.. so I should probably go with the bigger crank, and CTR/ITR internals, right?
I just want to make sure it's gonna handle the RPMs I'm looking for.
thanks again guys.. any other feedback appreciated.
[Modified by one.EG6, 5:18 PM 8/9/2002]
Old Aug 9, 2002 | 08:20 AM
WAFFLES's Avatar
Sleeving is great IMO, but there is just something special about a 1.7 b16. Very high revving(not that a resleeved b16 is not), and OEM internals. ADD a CTR head to the mix and your set!
Old Aug 9, 2002 | 08:27 AM
one.EG6's Avatar
ok, now another question....
pistons... the ones Spoon sells.. are they just regular ITR pistons in Spoon packaging? does the "balanced by spoon" have any effect, or is it BS?
Old Aug 9, 2002 | 08:29 AM
WAFFLES's Avatar
just BS...All OEM R pistons are balanced from the factory. When i took my USDM ITR pistons to the machine shop they said they couldn't get them anymore balanced.
And don't get ITR pistons for a b16 block, they will drop your compression. Go CTR or P30, those are the only upgrade.
Old Aug 9, 2002 | 08:30 AM
one.EG6's Avatar
thanks a lot.. CTR it is.
Cheez-It
Jul 19, 2006 04:32 PM
IDB4EVR
Feb 28, 2005 09:35 AM
rev-speed
Apr 12, 2004 05:58 PM
