how to take out 92-95 civic climate control
Old Feb 13, 2009 | 04:12 PM
Skadaloz's Avatar
Default how to take out 92-95 civic climate control
like the titles says...how do i take out the climate control on my civic...its not lite up so i want to check to see whats up and replace w/ orange blubs...
Old Feb 13, 2009 | 04:32 PM
turboedsohc89's Avatar
Default Re: how to take out 92-95 civic climate control
im sorry what do you wanna do i might be able to help you better i didnt understand your post..
Old Feb 13, 2009 | 07:09 PM
arrocha87's Avatar
believe he wants to remove the climate control from his dash to check wiring and replace bulbs. i need to pull mine too because the cold/hot slider **** is broken off and im tired of having to use a metal pin to slide it back and forth! lol
Old Feb 13, 2009 | 07:28 PM
Rev2 9K's Avatar
I think it is easier to remove the dash, it is held in by 4 screws
Old Feb 13, 2009 | 08:14 PM
joelmatt89's Avatar
yeah take out both dash panels and maybe your radio, so you can pull out the unit part way and then you will have to remove the plugs, there are to on the back and there is also a cable. The time i did it it was really a pain, the plugs were so hard to get out but maybe you'll have better luck
Old Feb 15, 2009 | 04:59 AM
Skadaloz's Avatar
is that the only way....i dont feel like takin out the dash
Old Feb 15, 2009 | 05:26 AM
joelmatt89's Avatar
i don't know if thats the only way but i know you need to be able to get your hand to the very back of the unit where the plugs are, because you can pull it out a little but the harnesses and cable will only let you get it out about half way
Old Feb 15, 2009 | 06:36 AM
EGCoupeVtec's Avatar
The way I did was I took out the radio , center console , then theres like 3 screws that hold the climate control , Theres two plugs on the climate control and thats about it ..Two screws on the climate control is a bitch to get out , you have to have skinny hands lol...If you have anymore questions let me know..
Old Feb 15, 2009 | 07:26 AM
whiteciv88's Avatar
take out the dash come on now
Old Feb 15, 2009 | 07:31 AM
Rev2 9K's Avatar
I had my dash out in 30 minutes, you can do it
Old Feb 17, 2009 | 04:14 PM
Skadaloz's Avatar
anyone has pictures of it
Old Feb 17, 2009 | 04:39 PM
Jimster480's Avatar
wtf pics/ writeup on how to take out dash? in 30 mins? i gotta take mine out so i can rewire the damn antenna.
Old Feb 17, 2009 | 05:23 PM
Rev2 9K's Avatar
Start by removing lower center console, glovebox, lower panel on drivers side.
6 bolts holding complete dash on. Open both doors, there is a small panel on each side, remove them and there is a bolt there. After removing glove box, there is a bolt on the lower right corner(as seen in pic) same goes for the drivers side but in lower left corner. Pop off the vent on top of the dash, bolt behind that. After removing the lower center console, the is a bolt near the carpet. Now pull the heater control cable off the heater box below the glovebox. Unplug any connectors(5 total)including pass side airbag there are 2 connectors behind the center console the others at the fuse box, remove the 2 nuts and 2 bolts that hold the steering wheel up, let sit against seat. Now on the pass side air bag, there are 2 brackets that mount the bag to the frame under the dash, remove the nuts. Now you lift the dash up and out if you got all the bolts out. I will add more pics later.
The four connectors at the fuse box(one big harness)
These are where the 2 brackets bolt to the airbag
Old Feb 17, 2009 | 05:45 PM
jxhxb's Avatar
wow i didnt know it was so simple to remove the dash!...i have all these vibrations within mine ive been wanting to pad up and try and stop them to keep me sane...maybe ill give this a try.
while on the subject of taken out dash parts.(not trying to jack thread)
but how do you take out the glovebox??
i dont understand it haha i dont see where to unbolt it?
Old Feb 17, 2009 | 05:57 PM
Rev2 9K's Avatar
2 bolts(8mm head)on the bottom of glove box take those out and there is a plastic arm on the side held in by a philips screw thats it
Old Feb 17, 2009 | 08:21 PM
joelmatt89's Avatar
yeah im not sure why people are so hesitant to remove interior panels like dash etc. it is really very easy and makes your life much easier although some panels i try not to remove depending on how they lock in if it is plastic things like on the door panels they wear out pretty quick
Old Feb 18, 2009 | 03:46 AM
Skadaloz's Avatar
koo ill give it a shot...
Old Feb 18, 2009 | 04:31 AM
cjtimp's Avatar
WOW.............. This one is cool...........
Old Feb 18, 2012 | 07:36 AM
Civic-Rookie's Avatar
I am currently removing my climate control and went through the radio area to do so. The only problem I am having is how to remove the ***** on the heat/cold slider **** and the low/high **** that slides..
Anyone have any ideas how these ***** are attached or how to unattach them
Thanks
Old Feb 18, 2012 | 10:43 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ Yes: Pull on them.
Old May 9, 2014 | 07:00 AM
eddiolop's Avatar
i dont mean to jack your thread but i would like to know how to remove the center panel around the climate control and stereo on my Honda civic ex 94 to carbon laminate it. Does anyone know how to do this or has pictures of it being done?
Brake_Check
Dec 18, 2013 10:29 AM
93gsrcoupe
Apr 8, 2006 03:05 PM
UNKNOWN_MEMBER
Jan 3, 2006 10:03 AM
Baron55
Jul 17, 2005 09:43 AM
Zoso1977
Nov 6, 2004 10:57 PM
