95 Accord Ex V-TECH Speed Sensor
I have seen this topic alot but none on what mine is doing. My cel is on and the only code that reads is the speed sensor. Changed the speed sensor, cleared the codes and still no speedo and the cel came back on and said speed sensor. What would cause this? I have put three differant speed sensors on this thing and still get the same code with no speedo? Can someone please help me
The wiring to the speed sensor may be bad.
Or you're replacing it with duds. If you've used three NEW OEM speed sensors then bad wiring. If you're buying used junkyard ones or $5 ebay ones I'd say it's possible they're bad. There's a reason the OEM one is $110 and the ebay one is $5
They have all been new ones. My dad owns a shop so the local parts store let me keep putting them on. This is the first honda that I have ever owned so I am new to these. Im used to high horse power v8's. Ok one more thing, I pulled the wires out of the connector that goes onto the speed sensor and when they touched together my girlfriend said that the speedo whent all the way aver and then it blew a fuse.
r u changing just the sensor or the geering part of it also I had that exact prob and it turned out to b the lower mechanical part of the sensor
