cams
Old Aug 9, 2002 | 06:46 AM
BEEFEDUPACCORD's Avatar
Default cams
What will a cam do for a 2002 sohc accord se? also how much do the cost, where to buy them, and what type of cam is best? Engine code is f23.
Old Aug 9, 2002 | 07:04 AM
b18bEG's Avatar
Default Re: cams
did you try a search at all, bet you'd find somthing
Old Aug 9, 2002 | 07:10 AM
Gennady's Avatar
New User
Default Re: cams
You will need 2 cams, even though it is SOHC.
Edit: Sorry, I was thinking you had a V6. To answer, not all that much if the rest of the engine is stock.
[Modified by Wont be beat, 11:11 AM 8/9/2002]
Old Aug 9, 2002 | 08:17 AM
Brandon's Avatar
Life is Suffering
Default Re: cams
Try http://www.gude.com. With some fuel management you can see gains of 10-15hp in an Accord. The reason for that is Accords were made with conservative fuel-sipper cams. Good luck .
DMV_4_14_23
Feb 8, 2010 09:53 AM
AccordCD5
Mar 13, 2004 02:23 PM
asiangel
Jul 24, 2002 05:53 PM
BEEFEDUPACCORD
Apr 14, 2002 06:15 PM
BEEFEDUPACCORD
Apr 13, 2002 09:37 AM
