out with the old, in with the new
did a rear disk swap on my car. really liked the results. got a prop valve from a type r civic (same thing as 99-00 si) but still, its type r... new rear trailing arm bushings, extended studs (no need for them at all but there cool) aem pads which i picked up from a guy for a cool free, steel braided brake lines custom made buy a guy off honda tech. good quality and a good price. 85 shipped for the set. https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/stainless-steel-brake-line-cluth-line-special-deal-back-%2425-shipped-clutch-lines-%24100-shipped-br-2345062/ and a set of el cheapo rotors. everything went smooth. thanks rick for all the help
the ****
old setup
out with the old
in with the new
all done
rick had at work
finished product
rear studs on the car. i have the fronts but you have to press out the wheel bearings to put them in. just havent gotten around to it yet. looks like its rear wheel drive...
and my rear end with my eye candy
thanks for looking
the ****
old setup
out with the old
in with the new
all done
rick had at work
finished product
thanks for looking
braking is much more responsive and much more even. not as much nose dive when braking hard.
nice pictures, aren't the extended studs so you can put slicks and stuff on with out a problem? iunno, doesn't look bad though.
Gotta perform better, and is a hell of alot easier to change your breaks when the time comes.
mb motor i think. got them off tires.com they are a knock off of something
medjosh6
Nov 7, 2008 08:20 AM
turbo sol
May 16, 2006 09:47 AM
