will EG suspension fit on a 92 integra?
Old Feb 13, 2009 | 11:42 AM
blk02ep3's Avatar
Default will EG suspension fit on a 92 integra?
as the title states will EG suspension fit on a 92 integra?
thanks in advance!
Old Feb 13, 2009 | 12:19 PM
Dilly's Avatar
Default Re: will EG suspension fit on a 92 integra?
not interchangeable.
it'll fit the DB's though.
Old Feb 13, 2009 | 12:51 PM
blk02ep3's Avatar
so i guess my only other question is; which other application will work if any?
Old Feb 13, 2009 | 01:01 PM
freakin_eLRoD's Avatar
check out this thread: http://www.g2ic.com/forums/showthrea...+da+suspension
Old Feb 16, 2009 | 04:55 PM
Steven.'s Avatar
You can use the front struts, and as for the rear struts the fork and the bushing is larger on the integra so they will not fit directly.
Old Feb 16, 2009 | 09:59 PM
KN13_Racer's Avatar
its a direct swap all you need is eg/dc front forks
Old Feb 17, 2009 | 07:08 AM
StokelesS_g2's Avatar
So much freakin' bad advice floating around.
Old Sep 21, 2009 | 09:35 AM
Steven.'s Avatar
You are the only bad advice here.
EusebioSam19
Suspension & Brakes
Apr 29, 2010 04:57 PM
gelok
12
Feb 13, 2010 08:06 AM
1 sLoW hAtCh
Jan 16, 2006 06:40 PM
B18C5NA
Dec 16, 2005 11:02 AM
