crx si no start
Old Feb 13, 2009 | 11:25 AM
Scotty_1988crxsi's Avatar
Default crx si no start
ok im friggin pissed i checked everything, main realy, not the fuel pump cuz it turns on i have spark my timing is good i think all the marks line up. my firing order is ok and im just not completely sure about the main relay tho i cant determine if thats wut it is cuz i replaced it twice and they all do the same thing it primes the pump but when you turn the engine over it keeps clicking and idk wut the problem is i have good spark i just dont kno wut else to look at any input would be great. oh yea almost forgot if i squirt fuel in the intake i hear it come out of the exhaust not even a fart from the engine
Old Feb 13, 2009 | 02:12 PM
philafelman's Avatar
Default Re: crx si no start
have you checked compression...if the car sat for a while maybe the rings got washed...try a couple drops of oil in each cylinder.
Old Feb 13, 2009 | 04:32 PM
fcm's Avatar
fcm
Old Fart
Sounds to me like there is no spark, or weak spark "if i squirt fuel in the intake i hear it come out of the exhaust not even a fart from the engine" you would think you would get something.
Any chance your distributor is out, [rotated] by 180 degrees? 94
Old Feb 13, 2009 | 05:40 PM
na i have really good spark trust me i saw it and felt it on all 4 i have msd. and it cant be 180 out cuz of the notch on the cam. and idk about the compression cuz i just put my hand over the valve cover wen my girl was crankin it and it was pretty strong i will out a leak down on it and a compression on it just to see were its at
Old Feb 14, 2009 | 08:07 AM
black97civic's Avatar
unless the compression is really shitty on all cylinder i would think it should still start or hesitate or somethin. u sure your injectors are fireing and i would check fuel pressure to just to make sure ur good there. also how did u check spark? im sure u checked it but the plugs may not be gapped right.
Old Feb 14, 2009 | 11:23 AM
yea i will do that but wouldnt it start and stop if i put starter fluid or fuel in through the intake?
Old Feb 14, 2009 | 06:31 PM
would a jdm ecu work on an american car and engine? obd0 tp obd0 obviously?
pmey
May 26, 2009 01:11 PM
just another ef
Aug 19, 2008 01:43 PM
CRXherbie91
May 14, 2008 05:49 AM
1 speedstar
11
Aug 23, 2004 01:08 PM
