tinted windows???
Old Feb 13, 2009 | 08:29 AM
8dxhatchy8's Avatar
Icon2 tinted windows???
anyone in here ever tint there own windows, ive tinted tons of windows but have never done a hatch.
I was just wanting some feedback cause im thinkin bout doin my windows they all look fairly easy except maybe the back hatch window........any info would help, thanks!
Old Feb 13, 2009 | 09:47 AM
Canadian_EF's Avatar
Default Re: tinted windows???
only advice i have is, get the professionally done. they will bubble otherwise, unless you yourself are very professional.
be careful taking off the rear window. i do not know how to do that.
the rear side windows are easy. just undo the hinge and the opening mechanism. very easy.
Old Feb 13, 2009 | 10:14 AM
aalb1's Avatar
I got my tint from TintKits.com The guy assured me that it was straight forward and I wouldn't need a heat gun or anything. I did the fronts and backs without problems, but the rear hatch window was a challenge. I ended up messing up 2 of the defroster lines as a result and don't have any tint on the rear window.
Maybe get the kit but get someone with experience to do the hatch.
Old Feb 13, 2009 | 10:43 AM
8dxhatchy8's Avatar
yea thats the only window im iffy on is the rear !
Old Feb 13, 2009 | 10:52 AM
handicrx's Avatar
be careful the hatch glass is super sensitive
i went to replace mine after a tap that shattered it, the guy putting the new one on didnt even wanna do it at first, he says its risky and too easy to break
Old Feb 13, 2009 | 10:55 AM
ALLxMOTOR EG's Avatar
Vietnamese!
i like me window clear,but that's just me.
Old Feb 13, 2009 | 01:05 PM
schueytenten's Avatar
Maybe I am crazy, or maybe where you live, tint is really expensive, I don't know. I just had tint done on a CRX. I removed the front four windows and let them remove the rear window tint, and I paid $105 for the whole job. That seems pretty reasonable. How much does a tint kit cost? Just seems like too much work to save what $40 or so, and have bubbles and other BS going on.
Old Feb 13, 2009 | 03:41 PM
jhammond_82's Avatar
Reject Papi
go on ebay and type in like 91 civic tint. there is a company that has pre-cut tint. they send it to you pre-cut and all you do is put it on.
Old Feb 13, 2009 | 05:35 PM
jdmlover07's Avatar
i did my own, and came out good, just take of rear hatch, take of the plastic cover, and use a heat gun and make sure its done evenly
Old Feb 13, 2009 | 05:42 PM
8dxhatchy8's Avatar
thats probably what ill do is take the hatch off....... that pre cut stuff is junk, turns purple and what not!
Old Feb 13, 2009 | 06:01 PM
90_EX_Civic's Avatar
all tint well turn purple. why, cause the cleaners that you use on it has ammonia(windex).
just make sure you clean your hatch glass with soapy water(use dawn) in a spray bottle. use a razor blade/scrapper to clean the glass. spray again, lay tint on(after taking off the wing). measure, squiggy the tint on, heat gun, cut, spray off tint. clean the inside off like the out side. spray the inside, ready the tint(peel off the clear) lay it on the glass(make sure there is decent soapy water to move tint around) squiggy off extra water. heat it a little after words. if you have bubbles, use a pin to pop the bubble, use heat gun on it to shrink it down.
Old Feb 13, 2009 | 07:59 PM
jdmlover07's Avatar
just make sure you clean your hatch glass with soapy water(use dawn) in a spray bottle. use a razor blade/scrapper to clean the glass. spray again, lay tint on(after taking off the wing). measure, squiggy the tint on, heat gun, cut, spray off tint. clean the inside off like the out side. spray the inside, ready the tint(peel off the clear) lay it on the glass(make sure there is decent soapy water to move tint around) squiggy off extra water. heat it a little after words. if you have bubbles, use a pin to pop the bubble, use heat gun on it to shrink it down.[/QUOTE]
exactly kinda hard at beginning
Old Feb 13, 2009 | 08:50 PM
shiza's Avatar
WRONG. They make glass cleaner specifically for tinted windows that does not have ammonia in it. Just go to any car parts place or the auto section of stores like Wal Mart and read the labels. The cheap stuff will still turn purple eventually but if you get a good brand they usually have a warranty against fading.
Old Feb 13, 2009 | 09:53 PM
8dxhatchy8's Avatar
i know how to clean and tint windows, ive had the same tint on my cutlass for 3 years and its still black, just was wondering about the rear hatch window if it would be difficult!
Old Feb 14, 2009 | 01:21 AM
SeanWard's Avatar
I tinted all the side windows my self, but got the hatch window done professionally, it cost 80 bucks
Old Feb 14, 2009 | 08:55 PM
barely4dr's Avatar
so-cal PD's give us alot of heat for having tinted windows
i rock the fish bowl look
Old Feb 14, 2009 | 09:15 PM
Radim's Avatar
No kidding, my brother got a ticket for his tint at LAX...
I also rock no tint... looks great on my Hatchback and tint only attracts attention.
Old Feb 15, 2009 | 09:54 AM
8dxhatchy8's Avatar
i know it does...i just want to do a light 35% theres just way to much glass and looks kinda weird, not to mention its hella bright!
Old Feb 15, 2009 | 01:55 PM
crxblues's Avatar
this may be right for some films but if you get a good quality charcoal film you will save yourself the embarrassment of having purple windows over time. doing the back window of the hatch will take some time and is not the job for a amatuer. i wet the rear window down with a dryer sheet soaked in soapy(outside of window with tint liner facing you) water and allow to dry. this makes a good surface for to tint to stick to while to "shrink" the tint to the window(basically making it form the same curves as the glass). shrinking the window to the glass takes time. i squeegee the middle of the tint to the glass so it doesnt go anywheres. next u are going to take a heat gun and point it to the parts that have "fingers"(wrinkles in the film) and hit them with a heat gun for just a couple seconds. u want to put the heat gun on it just so the tint wrinkles a little and then push the finger out with a towel on your hand. your going to do this untill u have the tint perfectly matching the curve of the galss and no fingers. after u are done that process(which takes a while if u want it to come out right) your going to want to clean the inside of the window really well and soak it with soapy water. remove the tint liner while keeping the adhesive side wet with the soapy water. than apply your tint by picking it up wioth soapy hands and begin to squeegee it on to the glass after placing into place on the window.
now a good tint job requires alot of cleaning of the glass. im sure i left out some steps but tinting techniqes come as u do it more and more. ull find which way works for u best.
Old Feb 15, 2009 | 02:00 PM
crxblues's Avatar
btw dont use a razor blade to clean the inside of your hatch glass. you will also scrape off your defroster as well if you do so. it is alright to use a razor on the outside though
philosofy1
Mar 10, 2009 09:46 PM
IHEARTMYHONDA91
Nov 11, 2008 08:27 PM
crazychrisjdmcrx
May 8, 2005 08:08 PM
RedHatch
Mar 28, 2002 08:43 AM
