crankshaft pulley hellp!!!!!!!!!!
Old Feb 13, 2009 | 07:44 AM
daylon1650's Avatar
Default crankshaft pulley hellp!!!!!!!!!!
here is the problem my honda accord lx crankshaft pulley has been casing me some problem ever time i put the crankshaft pulley and connect the alt. belt to the pully i turn on the car and it starts to wobble real bad what can be the problem.
Old Feb 13, 2009 | 07:54 AM
daylon1650's Avatar
Default Re: crankshaft pulley hellp!!!!!!!!!!
ive got a problem okay after i put on the timing cover then i got to the crankshaft pulley so i put on the alt. belt left off the power sterring to check if the crankshaft pulley would wobble so i turn on the car and push the gas it wobbled woreser than befor. the belt stated slipping of the pulley and almost started eating threw my timing cover so i turn it off wht could be the problem.
Old Feb 13, 2009 | 08:03 AM
redbull-1's Avatar
The crankshaft pulley (also known as a harmonic balancer pulley) should be replaced.
Old Feb 13, 2009 | 08:05 AM
daylon1650's Avatar
do you know where best to get one. and or are you talking bout the pulley thats on the inside of the timing cover
Old Feb 13, 2009 | 08:14 AM
redbull-1's Avatar
You can get it from Honda or aftermarket. It is the pulley outside of the timing belt cover. There is a layer of damping material between the pulley (red arrow) that is probably worn out, the pulley is not all metal.
Old Feb 13, 2009 | 08:29 AM
daylon1650's Avatar
do the key supoose to fit onto the crankshaft all the way
Old Feb 13, 2009 | 08:39 AM
TouringAccord's Avatar
H-T Order of Merit
yes
Old Feb 13, 2009 | 09:10 AM
daylon1650's Avatar
for some reason it dont for me it fits half way. and when i take the alt. belt off it stops wobbling and when i put on the belts that when it start back to wobble and the belt slips to the timing cover. could it be i dont have the bolt tight on enough
Old Aug 9, 2009 | 02:58 PM
Integra4lyfe069's Avatar
your keyset is prolly chewed along with your walls, replacing the pully wont do **** if ur keywall walls is chewed.
Old Aug 9, 2009 | 06:52 PM
nus_dogg's Avatar
New crankshaft; meaning new motor, if that indentation for the key is messed up.
ABCVTEC
Sep 10, 2010 01:01 PM
frosti108
Dec 14, 2008 07:39 PM
JDM H22
Honda S2000
Nov 20, 2008 07:18 AM
1994CivicGS-R
Mar 14, 2006 03:05 PM
Louie B.
Oct 6, 2002 06:09 AM
