Suspension & Brakes Theory, alignment, spring rates....
Searched and couldnt find answer - GC Tops on S2 Pro-c
Old Feb 13, 2009 | 07:23 AM
civicduty13's Avatar
Default Searched and couldnt find answer - GC Tops on S2 Pro-c
I am looking at doing some upper top hats but want to know if the gc ones will work on the Skunk 2 full coilovers? Any help would be greatly appreciated. Thank You.
Old Feb 13, 2009 | 11:47 AM
kyden's Avatar
Default Re: Searched and couldnt find answer - GC Tops on S2 Pro-c
why do you want extended top hats for the pro-c? the shocks are fixed stroke.
Old Feb 13, 2009 | 12:14 PM
wouldnt the top hats give me a little extra suspension travel so if I set it down low, it wont bottom out the strut?
Old Feb 13, 2009 | 10:24 PM
xd69's Avatar
If you are bottoming out a pro c, it means you are adjusting your ride height using the spring perches and not by shortening the shock. Therefore if used as intended, there is no need for extra shock travel
DialedLife
Suspension & Brakes
22
Sep 3, 2012 07:46 AM
deepgreengsr
Sep 14, 2003 02:42 AM
tegasaurus
Jun 24, 2003 08:43 PM
citanest
13
Apr 12, 2002 02:53 PM
hondacivic4g
Jan 14, 2002 07:26 AM
