GC+konis, or full coil set?
i'm looking for a good set of full coilovers or probably just coilover sleeves+shocks for canyon running and daily driver for my Civic 2000 sedan.
I want reliability with the suspension, and i heard gc+konis were a good combo, but anyone know of anything else thats good?
so far i'm on shocks and springs(eibach pro kit+tokico hps) the height of the car isn't to my liking and thats why i want to switch to a coilover set vice versa.
Suggestions please! thanks!
I heard that the GC squeek and make a lot of noises though is that true?? and what other stuff do i need to buy to perfect the set, like camber kit, or what else?
Decide how low you really want the car first. If you want to tuck tire in the front (or lower), you'll want custom rates with stiffer front springs (450+ lbs/in), to help prevent bottoming. If not, the standard rates are probably fine.
My GCs don't squeak.
why wouldn't or should i get front camber kit?
and so the rear camber kit isn't necessary because i can get longer bolts and washers, but i can still get the rear camber kit none the less right?
If you like your car to handle well, then don't use any camber correction. The closer you get to straight up 0 camber, the worse the car will handle, assuming that your lowering by itself gets you -1.5 to -3 deg. neg. camber.
The springs and shocks on a double-wishbone Honda are not affected by negative camber as they are independent of the suspension's geometry.
