Idle goes up and down
Old Feb 13, 2009 | 01:51 AM
chupau's Avatar
New User
Default Idle goes up and down
Hi Guys I hope you can help me, I am not sure if this is the right place, I have a problem with the idle when my car has just started and it goes from 1 going down to 0 and dies. But when it runs for about 5-8 kms it does not go down to 0, but goes up and down .5 to 1.5 RPM. Any help would be highly appreciated. Thanks in Advance!!
Old Feb 13, 2009 | 04:47 PM
acurtech6090's Avatar
Default Re: Idle goes up and down
what kinda car?
Old Feb 14, 2009 | 04:08 PM
chupau's Avatar
New User
oopss sory I own and EK 9b model ,, D16 engine
Old Feb 16, 2009 | 07:35 AM
might be a fast idle valve or iac valve. i would check to see if you have any coes first and that the coolant is good. low coolant can have that effect also clean the throttle
Old Feb 19, 2009 | 08:42 PM
jan_ello's Avatar
did you try checking your iac valves and cleaning it?
Old Feb 20, 2009 | 04:48 AM
mmuller's Avatar
Mad Scientist
check idle (unplug iacv and set to 550rpms)
make sure u dont have vac leaks
does your car car have a fast idle valve?
Old Feb 21, 2009 | 05:37 PM
chupau's Avatar
New User
Thank you guys,, I tried to replace the Throttle sensor and had the throttle cleaned ,, I think they also changed the IAC. Thank you guys you have been a lot of help!!
Old Feb 22, 2009 | 09:58 AM
Andr3w's Avatar
Clean ur iacv and your set.
protopro88
Apr 8, 2011 03:41 PM
LukieLuc
Oct 3, 2007 02:09 PM
crazykid9137
Aug 18, 2007 02:09 PM
90AcuraIntegra04
Nov 21, 2005 02:33 PM
Metal_SOL
Nov 19, 2002 07:05 AM
