EG auto to manual conversion: Block off plate?
Old Feb 13, 2009 | 12:19 AM
bluebomber's Avatar
Information Leafblower
Default EG auto to manual conversion: Block off plate?
I just did a conversion on my EJ1 and I was wondering if anyone knew how to cover the hole left behind by the auto? I was hoping to find a rubber seal or a piece of metal I could bolt down to cover the hole.
I'd prefer not to do any welding, something I could bolt on myself would be ideal.
Old Feb 15, 2009 | 09:09 PM
slomofo's Avatar
GDD Member
Default Re: EG auto to manual conversion: Block off plate?
Just a quickie thought...
Go to home depot in the HVAC section and buy a piece of sheetmetal, then cut it to size. Attach it by either drilling holes and using nuts/bolts to secure it or glue it down with weatherstripping glue, then go on the bottom of the car and spray some rubberized undercoating to protect moisture from seeping in, then cover the top with your center console.
XxD16xX
Nov 29, 2014 10:39 AM
pjr710
13
Apr 27, 2006 01:11 AM
Pro StylezLB
Feb 23, 2006 04:27 PM
AmericanHonda
May 2, 2004 06:28 PM
PornStarRacingB16T
May 11, 2003 05:07 PM
