obd0 b16 distributor??? help please
Old Feb 12, 2009 | 11:27 PM
bhigh's Avatar
Default obd0 b16 distributor??? help please
will any b16 disturbutor work or does it have to be a 0bdo becase im about to give up i cant find one and im building a sir 2 so any one got any ideas or suggestions
Old Feb 13, 2009 | 04:28 AM
Furyof4's Avatar
Default Re: obd0 b16 distributor??? help please
If your car is wired obd0 then you MUST use a matching obd0 dizzy. Check out Distributor King for a new replacement.
Old Feb 13, 2009 | 10:17 AM
greyrex's Avatar
Get it from distributor king...just purchased mine recently and it's great!
Old Feb 13, 2009 | 12:32 PM
bhigh's Avatar
on distributor king it does not say if its for b16 or not it just says jdm obd-0 so will a ls obd0 work or is the bolt pattern diffrent
Old Feb 13, 2009 | 01:16 PM
greyrex's Avatar
Looks like it's better you give distributor king a call.
This is what i've got...it's for my JDM B16A1.
Old Feb 13, 2009 | 06:20 PM
EF_LSVtec's Avatar
you can use an LS dizzy, except you have to cut one of the ears off..
Old Feb 13, 2009 | 07:01 PM
ef8sleeper's Avatar
^^^^yup
ive had to do this too.
just make sure that your o ring is sealing tight
juanintec
Aug 15, 2007 07:37 PM
Lo-Buck EF
Jun 30, 2005 02:27 AM
